Jswain's active projects
Nothing crazy here but I have seen a few members talking about tool centre height gauges for their lathes. Got me thinking closing the jaws and eyeballing it wasn't enough
Perfect! Looks just like mine. I even put a flat on mine like yours after the guys on here convinced me that it was worth doing.
I often tell others that this should be your very first lathe project.
DTI may have been more accurate? But I trust the accusize more then my 19$$ DTI
I appreciate your point. But there are a million reasons why you really should get a dial test indicator.
You did a nice job. But it's worth making a few points for the benefit of others who see your post.
End mill shanks are sometimes undersized vs their specified cutting diameter. You need to measure them to make sure one is exactly half of the other.
Since you did use a test indicator, and since you positioned it vertically, you could have just used 1/2 of the diameter to find the half way point. That way only one end mill is needed.
Again, nice job. It will bring a smile to your face every time you use it! That's what mine does for me!
Honestly I never thought, seen or heard of it til here in the last few weeks reading posts.
And with how easy it is, I now agree.
All of my tools were out(mostly high) except for my parting tool which I was very happy about because I've never had issues with it(knock on wood) so wasn't looking forward to changing it.
It's going to sit on the desk now and every tool change will get a quick check. I tested down the length of the bed and everywhere was within .001" so it sure will be handy.
I do have a dial test indicator, but it's extremely cheap and I don't know how I feel about it compared to the accusize.
There are a lot of measuring tools that I need/need to upgrade, and eventually I will
I did mic the endmills 6mm = .236" and 12mm = .4724"
I thought the 2 endmill method was clever because then I don't have to grab the indicator at all. If I left the 6mm endmill out I would need to lift the indicator .250" to get a reading on the 12mm endmill in the chuck and I've had limited success with having to move the indicator that much & get consistent reading. Maybe better tools / more experience will change that.
Oh, those comments were just aimed at others reading your post. Yours was just fine. Over the years I've run into all kinds of guys who never knew about a lathe height standard and just as many who figured other methods were better. I've used all the other methods and that is the best one hands down. All that's needed is a big old bolt or a chunk of bar stock. Doesn't even matter what material.
Start saving your loonies and toonies and get one of these for yourself next Christmas.
They are not cheap. And better deals do show up from time to time - even on Amazon. But the long barrel that the indicator needle is on together with the interchangeable tips make this one the best I have found. If you only want tenths, and don't care about the barrel, the interapid is also first rate.
I'm pretty focused on the machining tools now as I have basically most of what I need for everything else so over the next couple years I should get tooled up well enough.
Until a good deal comes up on Kijiji and something gets upgraded/new project :p
Sure, right or wrong this is how I did it:
I didn't have a dial test indicator at the time so I turned a piece of stock to .750" about 3 inches long. Near the end I drilled a hole sized for the adjustable arm off my mag base, & drilled and tapped a hole into the end for a set screw to hold the arm tight.
Mount that with a .0005" dial indicator in a 3/4" collet & the indicator vertical. I did this with the vise off. It gets the indicator ~5 inches ish off centre of the spindle. Come down with the spindle for just enough preload on the indicator for a good reading but not enough to have to mess with it dropping into the tslots.
Then I just turned the spindle, by hand, from the top to not influence the indicator and grabbed side to side readings off the same slot of the table and also corner to corner. I didn't notice much if any nod front to back so I loosened the 3 swivel bolts for the head just enough that I could get it to move with a deadblow on the side of the housing.
Get it almost perfect, repeat measurements, tighten a bit, rinse and repeat as it took a few tries and I probably need to do it again as I've moved the machine a couple times & when using my face mill it's definitely cutting a thou or two more on the right side of the cutter vs the left.
I will probably try it off 123 blocks this time with the vise on & see how that goes if everything clears.
I'll take a photo when I get back outside of the setup, it's nothing fancy but it's what I made when I bought my craftex mill
Lots of machinists prefer a little bias because the finish is better. I'm not so fussy about finish so mine is set level.
I've spent the last few days playing with the South bend, I wanted to check spindle play etc. on it as I had the spindle removed when I first bought it and installed new wicks. Spindle looked as new and the wicks must be doing there job because the play up/down front/back is all very good so I made no adjustments.
Also took the apron off to clean it. Half nuts are definitely worn(according to my, inexperienced opinion lol) but I think still fine to use? I have no issues with them & they engage fine, never disengage on their own. Thoughts?
All in all, pretty happy for a machine that's nearing 90years old. With the tool height adjustment and all the tune ups it is night and day difference with how well it is cutting, less pressure and much easier to hit tolerances.
Also I decided that I needed a new chuck key. The small ones are too small and the speed key is nice but can't torque it with it so would rather just use one.
Nothing fancy about it but I'm happy how it turned out. Did a .002" press fit on the ends. I used 1/2" stainless fairly thick tube for the handle will see how that holds up. Gives it a lighter feel but feels nice in the hands.
Have also been forcing myself to use the 4 jaw on the lathe, so getting better at dialing it in.
Try one of these made by our own member @a smile. You will love it. He hasn't been around much lately. Prolly up to his butt in gators.
Nice feeling isn't it! Well done!
I have seen his chuck keys on here and they look amazing!
Nice chuck key Joe.
Thanks for dharing your tramming procesure and results.
How ever. This spinning and measurements off the table is for the head tram and nod. Did you do a column tram as well?
Thanks !
Nice chuck key Jeo.
Thanks !
I have not tried a column tram yet, that's probably a good idea.
How are you doing yours?
Isn't that the same thing as head tram and nod????
What am I missing?
I think it would be if you wanted to shim the base of the column to remain square when adjusting z up and down.
I believe you need a long precision piece standing straight up on table and shim column to keep indicator on 0
Nod would be adjusted by shimming the swivelling portion of the head I believe. Which I did not do either as my indicator was reading the same front to back
But unsure as I've never done it
I am in unfamiliar territory.....
But it seems to me the only way it could change as the head is raised or lowered is if the column was bent. That's a MUCH bigger problem than Tramming.
Now, if we are talking slight x&y translations as the head is lowered and raised, that's a different matter. I don't think I've ever seen that discussed anywhere before. It might be one of those things you almost have to live with. Boy, talk about a dogs breakfast......
Ive seen on the interwebs people shim or epoxy the base to make the column straight. I think it would highly depend on the mill/quality of casting/what day it came from the factory.
Beyond what I'm willing to get after at the moment lol
