Jswain's active projects
Ive seen on the interwebs people shim or epoxy the base to make the column straight.
Ya, lots of guys do that. Some use shims. But that's usually done to fix nod not z-related changes.
Not saying it couldn't do Z related changes, but I've never seen or heard of anyone doing that. It would be a dogs breakfast.
It would be almost as bad as changing the Z-tram on a knee mill. It can be done, but holy crap. I wouldn't bother.
The column tramming in X and Y plane. Is so when you move your head up and down on the z axis. As I understand it.
I am using a precision granite square and hoping back and forth between X and Y wile shimming the column base.
Once you are happy. You move onto the head. You can adjust the tram on the X easy as our RF45 can rotate. But for the Y nod, we would have to shim the head between the Z axis sliding attachment, the saddle ( the portion that holds the gib strip ). If that makes sense to you Joe.
OK, but how do you do that without already having nod and rotate done, anything you put on the bed would indicate a false reading.
The way I understand this, this would have to be done first, not last or you end up chasing your tail.
If it's done first, you still end up have to change the Z tram which throws out the x/y.
A never ending circle.
I'd be inclined to live with any Z error that exists. It's not any different than a Bridgeport. If I had that error I'd just accept it and move on. At worst, I'd measure it and take it onto account.
This pretty much puts everything I am thinking into words and visuals!
That's a good video, thanks I saved it for the future. I may test with a 123 block that's about as long as a precision straight edge I have for now.
Probably will be best for me for now
In the very near future I plan on pulling x/y apart to clean & get rough measurements for making a new x axis nut.
When I get it back together perhaps I can check column tram
Well the mill was a little jealous that the lathe got a new chuck key. So I attempted to make one for it, but not everything works out.
I used the bolt hole feature on the fswizard app and navigated with my dro(it doesn't have the bolt hole feature).
That portion went well but when I connected the dots you can see it wasn't even. I believe this is probably due to the hex er32 collet block not being concentric to the bore.
So now I will see If I can do the same as the square er32 block to improve that, then retry the internal hex cut to see how much of a difference it makes.
Getting much better, think I will try dusting up the 1 highest side and hopefully leaver b. I took the first measurements then rotated the collet 180 degrees for the second measurements, so I believe most of the runout is still in the block.
This one is much harder then the square was. Pulled out the mister and just used it with air which I quite liked so I may come up with a good mount for the mill & have it somewhat always rigged in.
You can see the homemade mag base I cobbled together with 3d printed parts. I got the mister with the South bend and figured it would come in handy someday.
OOOOooo. A mist setup. Can you elaborate ? Lol
Nice work, I have a Chineseum hex block that is just as sick as yours.
Thanks !
Thanks !
It's an amflo 270 coolant mister. Hook it up to air and shove the hose in your coolant(or just use air) and you can adjust both the airflow & coolant flow to mist the tool without the mess of flood cooling.
You can get a generic one on Amazon for very cheap, like $20 or something
And you can see my homemade "mag base" better here
The hex er32 collet block turned out better then I could hope(realizing if it's out front to back I still have yet to fix that issue)
Definitely much better. Not wanting to waste anymore scrap to find out it wasn't going to work i went up to the next size I figured may be handy.
I will need to make a vise stop for repeat positioning of the block when I rotate it but other then that I'm thinking it will be good.
Not bad for a mishap. Halfa$$ matches the chuck key. I'm a sucker for having the tools needed for the machine at the machine so I think it will live next to the tool centre height standard.
Just gotta make one for the mill vise now.
That is NOT being a sucker. I think that's wise, efficient, and even necessary. Imagine mounting a chuck, holding it on with one hand, and then the chuck key is out of reach..... Not good.
3rd times the charm....
My attempt yesterday I changed to a 6mm carbide endmill to do the 6 corner holes and the radius was just too big so it turned out more like a spline socket with very little engagement. Probably would have worked but I wasn't happy with it.
Today I used a centre drill on all the holes then a 1/8" drill bit for the corners. Then drilled out the centre with a .450"ish(I forget the fraction size) drill bit. And then skimmed the sides with the 6mm carbide end mill.
I took the endmill to the exact size(should have went a thou or two more but was nervous to oversize it) and then skimmed it to a perfect fit with a dremel stone. Fits the vise in all orientations perfectly.
Now just needs a handle
Superb!
I'm pretty focused on the machining tools now as I have basically most of what I need for everything else so over the next couple years I should get tooled up well enough.
Until a good deal comes up on Kijiji and something gets upgraded/new project 😛
Well that didn't take long 🙄
