I don't think that is a distinction that I am allowed to make...... Scientifically, I might be biased....🙄Is it a special talent or are you just,,,,, "special"? LOL
Thanks, I wish that there was a little more time to stick with it a little more, but it is hard with spring in the air.....Looks great. You're getting pretty good at that. When you're done there, you wanna come over and do some patch work on my mower deck?
I just keep reminding myself, that if it weren't for the screw ups, there'd be no sex here at all....... 😳No tin brasher ever learned the art from a book. The only way to become proficient is to put in the time and make the mistakes. From what I’ve seen, you’re doing great!
I always think that one of these days I'll actually get a season ahead, but it's always reactive maintenance on "in season" junk lol.Thanks, I wish that there was a little more time to stick with it a little more, but it is hard with spring in the air.....
At the speed that I work, we should probably start with the snowblower, it's a little late for mowing season. 🙄
I have one sitting in a box. Tried it a few times. Same issue. Hard to use.A while back I bought one of these 18" offshore bead rollers, and while you can roll a bead, it's not the most user friendly thing, trying to crank the handle and feed the sheet in straight.
I had an old ATV winch taking up space and a few ideas gleaned from YouTube....
I cut the outside end of the drum off, bored the center to fit the drive end of the bead roller that I turned down to 3/4" so I would have enough meat left on the drum for set screws.
Welded a mounting bracket for the winch motor, and we have a basic powered bead roller.
I have a motor controller downstairs for it that will give me speed control, as well as forward/reverse, all for around $20.00 on Amazon. Just going to power it with a deep cycle battery for now.I have one sitting in a box. Tried it a few times. Same issue. Hard to use.
Uh....and where are the puppy ruckus pictures ?Another well documented problem with these is the amount of flex in them, I could get almost a 1/4" deflection with just my fingers....
I beefed up the backside with 3/8" x 2" flat bar bent and welded on. The small plate with the 2 bolts serves to align, and stiffen, as well as mount a fence.
The start of the fence on the other side. I got this far and the puppies started creating a ruckus, so it was time to stop for a while.
I know, right?....... For someone who is supposed to be trying to sell the last two pups, you would think he'd have a few pictures....... I wonder what is up with that? Although, I think the wife might be on to my antics......🙄Uh....and where are the puppy ruckus pictures ?
The original idea was to use the same base for my tube bender, but in reality things are getting too heavy to swap back and forth so I will be making a new stand at some point.I also like how you repurposed a truck hitch.
Wash the leftovers of yer last meal outta yer beard, and see if they still do! LOL!I know, right?....... For someone who is supposed to be trying to sell the last two pups, you would think he'd have a few pictures....... I wonder what is up with that? Although, I think the wife might be on to my antics......🙄
These last two are going to hard to let go of, they even seem to like me......😱
