Tool Vevor Drill Bit Sharpener Improved
Tool
My parts were printed on a printer that had not been calibrated, and I'm finding the 28mm bores wont accept the chucks without chamfering and sanding.
@DavidR8 can you let me know if this is an issue when you visit @YotaBota please
My 8mm threads formed very well, and I ran them thru with one of my many 8mm taps. The tool insert block snapped right into the block holder...
Assume I can just measure with inside mic?
Yes that should work just as well.
The width was verified against a number of different chucks to it has to be just the printing of my part. Sadly I dont have any inside mics and I dont know where my brother keeps his so even if I ran to his place I'd be out of luck
.14mm undersize
So I noticed another issue. The motor boss wont fit into the motor mount. It is printing smaller than the actual model. I made the tolerances too tight. I had to sand mine which is frikken annoying. I'm making new stl file with slightly larger opening..
Duo Motor Mount Rev2
I got my parts ready to install, but now I wont get to them tomorrow because I didn't get my amazon order in on time. My wife came home in a panic because she spotted a stray dog and made me go out and hunt it down. Then it had no collar so I had to run it to my vet before they closed.
Thank god the dog was chipped... because the last thing I need is a golden doodle the size of a horse.
Temporary solution to hold the block in place for a photo using two 8mm taps.
