Tool Vevor Drill Bit Sharpener Improved
Tool
It makes me realize that 3D printing the collet nut might be more useful than even the collets. Easy way to control the length of the grind.
Brain fart. Woke up realizing that a custom 3D Printed Holder won't work. It's the gauge depth during setup (for more grind) or during use (for less grind) that has to change, not the holder. A longer or shorter holder won't change the drill grind. It indexes to the gauge set points regardless.
print collet holders with different depths
That was my initial thinking. Then I realized that the gauge and grind stations will simply take that into account and change nothing. The change has to take place between setting and using. Either set long and use normal, or set normal and use long. Both require a shim or some similar adjustment.
