Parker Majestic refurb
DavidR8
Scrap maker
Update: the VFD for the grinder arrived today! :D
Teco L510-101 from emotorsdirect.ca
DavidR8
Scrap maker
Also got this cool line drawing for the coolant pump.
It's a 3-phase pump so if I go the flood coolant route I have to get another VFD or setup a standalone system.
I'm thinking maybe a Fogbuster is a good route. Not keen on a mist system as I don't want the vapours hanging about... Happy to hear other perspectives.
  • SKMBT_C554e20121509310.pdf
I'm kind of curious about VFD retrofit motors for grinders for a project that wont leave my brain alone. Using your link, if I filter on approximate HP + 3-phase + general purpose, lots of candidates but all in the 1800 rpm range.
https://www.emotorsdirect.ca/search...al-Purpose&product-subsubcategory=Three~phase
When I click on any generic bench grinder, rpm is usually ~3500. I suspect related to target grinding SFPM at that wheel diameter
https://www.amazon.ca/King-Canada-K...d-search-10&pf_rd_t=BROWSE&pf_rd_i=7205691011
I know your application is probably different. Or maybe not, is it pulleyed up to achieve grinding rpm or is there some parameter I'm missing like KV?
Also for grinding applications, is there some parameter about the enclosure/breathing that makes it suitable for this kind of (potentially dirtier) duty?
DavidR8
Scrap maker
There's no pulleys, it's direct drive.
I've been told that a 1700 rpm motor can be run at 3400 rpm without issue.
For a grinding application I would only buy a TEFC - Totally Enclosed Fan Cooled motor.
That said, their filters don't seem to work 100% correctly. Send an email to them to ask. They are super helpful.
DavidR8
Scrap maker
Fired up the P-M today. Definitely exciting because I hadn't seen it run because there was no power in the warehouse. Running off a Teco VFD.
There's more noise from the fan on the VFD than from the spindle.
Huge sigh of relief!
DavidR8
Scrap maker
Had a few moments today to work on the grinder.
There was a pretty good buildup of crud on the table handwheel so I took it off for cleaning. I knew the hub that rotated the table worked off a gear from the handwheel shaft but I wasn't expecting this arrangement. The handwheel connects to a short axle with a small gear which drives this larger ring gear (I'm sure I don't have the terms right) which is attached to the hub shaft.
Quite an elegant arrangement.
DavidR8
Scrap maker
Bands are on!
The instructions from Parker Majestic say to fill the oil wells halfway so I’m waiting on a delivery of way oil from KBC before I reset the table.
DavidR8
Scrap maker
It lives!
Undressed wheel because KBC is sold out of the diamond dresser I ordered.
But the table went back on just fine.
Table is silky smooth.
Definitely takes some coordination to grind smoothly though I can see it being a bit of a zen activity.
Precision objects, here we come! LOL
Are you going to use the default coolant system or you have something else in mind?
DavidR8
Scrap maker
The pump is 3-phase so I'll need to get another VFD or I could just buy a complete system. The tank is a real brute. It's made from 3/16" plate and probably weighs 100 lbs empty. Other than the tank and pump there are no other coolant parts. So all of that will also need to be sorted out.
One advantage of using the existing system is that the tank fits neatly under the grinder though I'd have to pull it forward to get it back in.
So for about the same money as a VFD I could get a full system but I haven't done a lot of research yet.
I'm not a pump expert but maybe its constant flow & more/less fluid at the nozzle might just be diverting more/less to bypass with the valve?. ie. maybe you just need a matching watt/rpm 110v motor vs variable rpm capability?
DavidR8
Scrap maker
Indeed.
Coolant flow is likely best controlled by a valve and not by lowering the speed of the motor.
The hesitation I have with the existing pump and tank is its weight. I have to use a hand truck to move it so trying to wrestle it out when it’s in the base against the wall would be a nightmare. It also requires the machine be a full 18” -24” away from the wall and I can’t afford to give away the floor space.
I will likely clean it out, take the pump off the tank, put it in the tank and either put it back in place or store it and put a plastic tank system in it’s place.
historicalarms
I have another "cheap bastard-farmer fix" for you. My lathe didn't come with a coolant system of any kind so, after reading all the old "how too" books on machining, I decided the only way I was going to get any satisfactory turning results was to purchase an add-on spray system...but holly damn they were "spencif" from the store-bought place.
So the "what would I do if still farming" brain mater slooowly started to turn, and kicked into high gear the day I had to pick the wife up from the Greenhouse supply store she worked at. Just inside the door they had a display of garden/fish pond submersible pumpsso I picked out a mid priced one (around $40 but I cant remember the GPM rating). wish I could remember because it was twice what I needed.
She was a little late getting home from work that day as I needed to make a stop at CT for some feet of plastic tubing(1/4") and an assortment of brass hose couplers& a couple of valves.
I originally cobbled the pump & hose direct together with a nozzle at the end and plunked the pump into my reservoir with a couple gallons of cutting oil solution...a surplus five gallon plastic pail, and let er rip...this is when I discovered I had waaaay more GPM than I needed...that $hit was like red hot sauce...it went everywhere.
So back to the drawing board and installed a needle control valve in-line with a return line plumbed in just before it (between needle valve & pump). Now I could control the flow & pressure at the nozzle easily and the excess just flows back thru the return.
runs on 110V & Total cost was probably under 60 bucks, 250 less than store-bought at the time.
I did "store bought " one of those $8 flex nozzles that BB sells later on for the system but that's about the only change I've made in the more than 20 yrs I've used it.
DavidR8
Scrap maker
Now that I've stopped laughing at the mental images of coolant going everywhere at high pressure.... Thanks for the grins :D
This is exactly the kind of setup I'm thinking about, but I think I hear you saying to go conservative on the GPH rating :eek:
RobinHood
I agree with @historicalarms : you don’t need much. As a matter of fact, my Carolina Industrial bandsaw comes with a Little Giant pond pump for coolant from factory. Plenty of flow through a little 1/4” plastic tube. I even turn the needle valve all the way down so I just have a trickle.
My SM 1340 has the “submersible-pump-in-5 gallon-bucket” coolant system (designed by the previous owner). The tubing is 1/2”. I have only used it once - way too much flow. Coolant goes everywhere. So I just put the coolant in a spritzer bottle and use it that way (if I need coolant).
I prefer cutting oil for lubrication as I just don’t like the idea of water-based fluids on clean metal surfaces. Probably just paranoid that it would rust.
I know all modern CNC machines use coolant (water based for the most part) without any problems - maybe some day my old brain will be ok with it and i will switch.
