Lost in the Great Crash of '23, but not lost to my shop. I got the Harold Hall grinding rest pretty much completed today, with a little holder to take my QCTP holders and orient them to the wheel appropriately:
The little block of mystery metal accepted the dovetail well, but seriously chewed up my drill bits. One happily shattered while drilling the hole to hold the block in the slot. That's the reason the grub screw to hold the dovetail to the holder is 3mm instead of something a bit bigger - my 13/64th (M5 tapping size) bit no longer exists. Yay?
But it works, and I'm surprised how much better the surface finish is on my turnings with the tool sharpened a little more carefully than I had been before I had such a handy rest.
I'll probably remake it when I find a piece of mild steel large enough for the task - I'd much rather cinch the tool holder to the table from above than from below with a hex key. And there's no hope I can get that hole drilled in this stuff!
Mystery metal for the win!
Paul
I wish I had tracked it. It's been a side project in the shop for a couple of months. I'd say I'm 30ish hours in? The more recent hours have been much more productive than the first few. If I had dimensioned my stock intelligently instead of piecemeal I'm pretty sure I could have spent 8-10 hours less.Hey Paul do you have any idea how much time you have in the Harold Hall grinding rest?
It looks great. I’ve been thinking about one for some time.
Do you think the design is good as it is?
Art
Quick guess, likely a little heavier than you expect for the size (subjective of course), appears to start to drill nice just before it eats the drill, has a nice shine to it, cuts clean when you can machine it.Lost in the Great Crash of '23, but not lost to my shop. I got the Harold Hall grinding rest pretty much completed today, with a little holder to take my QCTP holders and orient them to the wheel appropriately:
Paul
The block turned itself 90 degrees up in the vise, just as I was clearing up the 4th face. The only injury is the 1/2" end mill, which is now running somewhat out of true. And a skipped heartbeat or two.
Aluminium is both *slippery* and *grabby*. Both holding faces were freshly milled, flat and parallel to one another.
Any tips for holding this stuff more securely in the vise?
Lucky it only bent the endmill, I've snapped a 1" one that way and it flies afterwards like a rocket bouncing off anything it hits luckily I wasn't in a part of the path. I'm going to suggest the endmill is toast. Also tram your head to ensure its still true. You be surprised how much force you applied in those brief heart stopping couple of seconds.So I started remaking the jig to hold my QCTP holders to the sharpening jig. And I did have some aluminium on hand, though in awkwardly large sections (4"x4"x40"). So after a long time in a saw with too fine a tooth pattern, I got it mostly squared up, when the oops fairy showed up:
Paul
What RPM were you using? What depth of cut?So I started remaking the jig to hold my QCTP holders to the sharpening jig. And I did have some aluminium on hand, though in awkwardly large sections (4"x4"x40"). So after a long time in a saw with too fine a tooth pattern, I got it mostly squared up, when the oops fairy showed up:
Paul
Definitely hits the "a little heavier than expected", and the nice-until-bad.Quick guess, likely a little heavier than you expect for the size (subjective of course), appears to start to drill nice just before it eats the drill, has a nice shine to it, cuts clean when you can machine it.
Likely a chrome moly steel type.
One word Carbide.
Though nicely done, enjoy.
It wasn't particularly bouncy - each of those streaks is one edge of the cutter grabbing and pulling!I am amazed at that pattern on the block. It suggests that things were bouncing pretty badly too! That doesn't happen so easily on such a big mill.
Yes, not super-smooth. The end mill was a bit ratty to start. Was running slower than I should have been (~1200rpm, vs the 6k rpm the usual charts propose for a 1/2 end mill in aluminium), and maybe feeding too fast.A zoom in on the freshly milled holding surfaces suggests they are not super smooth.
I was absolutely clamped at the end, expecting to mill the end of the blank in the same setup. And I was in too-high parallels, instead of changing them out between facing the edges vs faces.
You aren't the first or likely the last to bend a tool for one reason or another.
Whenever I use this tool I consider the feed rate at the high end for production rather than home hobby.
