That was a trick to use if it was a metal water line, put a cable from the welder to each end of a section of line and put the juice to it. Warmed the pipe up, melted the ice, sometimes “warmed” up other things depending on where the pipe ran! Soldered joints sometimes “desoldered” too.
Battery powered tools, around the farm they are indispensable. On sat we were doing some work on a calf shelter, had the drill, sawsall. sidegrinder and impact driver in use.
I don't have a farm but I do live on a rural acreage. I had a new fence built and one of the places I had the fence replaced was around the lagoon. The lagoon had the only fence that was actually page wire, the rest was just a 5 wire fence. To deal with the page wire I got a cordless angle grinder and a box of zip cuts and cut it up into 6 foot sections which would fit into the box on my truck. It had an 8 foot box but 6 foot pieces of page wire are easier to handle. The whole job took half the time it would have if I had chopped it up with my bolt cutter. I still have most of the zip cuts.
I think it was an old Fourny book I found had a number of things an electric welder could be used to do, a couple of carbon rods in the “special holder” for heating stuff. The holder held the rods and a pivoting toggle allowed one rod to be moved closer to the other to maintain a slight distance between them. Could be used to heat for cutting, bending, soldering, possibly brazing.
I need to have a look, might still have the book. It was full of possibilities for a 10-11 year old!
We had one of those w/ our old Forney. I struck an arc w/ it a few times just to see what it would do. Never actually used it for anything.
I bought the M12 one. Really handy while putting on these crash bars.
Apparently Milwaukee has a new line of M12 Extended Reach Rachet Wrenches. You can get 1/4, 3/8, and 1/2" drives. Very cool!
I had been told that using an impact wrench on big threading taps was the way to go with a guy repairing a D6. I thought yeah, right, that'll shatter them fast enough.
So yesterday for the first time I had 22 holes to tap at 1/4x28 for grease nipples. I got brave and drove the tap wrench with my Milwaukee impact driver with a adapter to 3/8.
Wow.
I'm going to buy a set of those tap sockets at Princess on Wednesday.
Just seeing this thread for the first time. Never heard of tap sockets. Seem like both a great idea - and an excellent way to break more taps faster.
Depends on power source, right? If a power tool, sure. But a socket wrench would make going off-axis so much easier.
Agreed, how you start a tap is critical. The ratchet isn't impact, gives you a pretty good feel. Using a tapping block would help prevent a crooked start
I've been using tap sockets for a little while and love them. I seldom use them with a ratchet wrench. While that is possible and perhaps even required out in the field, the best way to use them is with a tap guide in a mill or drill press.
I've even made a few adapters to make this possible or easier to do.
See the following post for lots of discussion about tap sockets and tap guides.
Follow-up to this post on the Southern Forum, which referenced this thread (purchased from Zoro, with added bonuses since they were drop-shipped directly from Eight Tools (box & brochure):
I took the Kobalt Set out of the HF stand on my "Stand Up Bench:"
Cleaned the stand, and placed the Eight Tools in their new home:
I need to find a storage solution for the 7mm, 7/32",9/64", 7/64" & 0.050" Kobalt's that aren't included in most sets. Was thinking of printing a block that will fit in the center of the stand for them and the "Pipes" that came with the Eight Tools Metric set; however, I realized that would lock me into just the holes in that block, so I'm going to finally use a piece of the 2" thick Acetal I got in a Protobox from OnlineMetals a 7 years ago (20lbs. for US$22: paid more for the shipping!).
