Hi Guys,
The local Lidl is currently doing a Chinese one, £7.99p about ($16) Its packaged in a similar way with a movable handle. It doesn't click but you can feel a slight tension on the handle as you pull it back. I would guess that its similar inside to a roller clutch.
I think you owe it to us all to buy at least one more and to tear this one apart and post up lots of pictures so we can all see how these work.
Well, I actually did find them at HD for US$16.67 (after my Veteran’s discount, with free shipping), but I’m not going to tear one apart since the manufacturer already did:
(from the listing on Amazon)
Zero•Drive also has an exploded diagram & description of their (higher priced) version:
I read the description but I don’t follow how it works…anyone care to reinterpret that for us?
If you ever owned an old tractor, and cut brush, then you either know what an over running clutch is or you filled your pants inadvertently at least once.
omg 🙄 😀 fine I'll go answer my own question....
I already did.
If the tractor analogy doesn't work for you, then look up overrunning clutch. But the scary tractor experience is waaaay more fun!
I already did.
Yes it is: I got used to my Lawn Tractor pretty quickly since I had experienced manual transmissions, but it was fun watching my wife trying to use it; she eventually gave up (and I learned how to drop the deck and replace the drive belt!).
The way it works is called an over running clutch. They turn one way but not the other. Here is a short video. But you can fast forward to 35 seconds for the explation. Over running clutches use balls or rollers on ramps with springs to hold them at the engaged end of the ramp. They turn freely in one direction and grab instantly in the other. On the wrench, the function is also reversable.
I'm basically shocked that nobody chimed in about the tractor example. I had expected lots of tales of horror and accidents. Early tractor PTOs were driven directly by the transmission output. So if you were using a PTO driven impliment like a bush hog (the most famous impliment of all), it didn't decouple when you threw in the clutch. Instead, the huge blade of the bushhog acted like a flywheel and kept the drive system going. The inertia easily overpowered the brakes. You usually threw in the clutch and applied brakes cuz you needed to stop, but that evil massive blade would not allow it! The result was barns and other things being driven over! It was pure evil! Operators learned early (or died) that the solution was to ignore your instincts hit the gas to accelerate and throw the tranny into neutral. Then use the brakes! Perhaps there were some where even that didn't work.
The field fix was an overrunning clutch on the PTO. This allowed the tractor to power the mower but the mower couldn't power the tractor. One way power transmission just like the wrench.
Modern tractors include an over running clutch and a regular PTO clutch so this doesn't happen anymore.
I'd still love to hear member stories about the time they plucked all the chickens in the the chicken coop with their mower and Ford 8N tractor.
I'm basically shocked that nobody chimed in about the tractor example. I had expected lots of tales of horror and accidents. Early tractor PTOs were driven directly by the transmission output. So if you were using a PTO driven impliment like a bush hog (the most famous impliment of all), it didn't decouple when you threw in the clutch. Instead, the huge blade of the bushhog acted like a flywheel and kept the drive system going. The inertia easily overpowered the brakes. You usually threw in the clutch and applied brakes cuz you needed to stop, but that evil massive blade would not allow it! The result was barns and other things being driven over! It was pure evil! Operators learned early (or died) that the solution was to accelerate and throw the tranny into neutral. Perhaps there were some where even that didn't work.
Thanks for the details on the true overrunning clutch: I was envisioning a more mechanical implementation of the slack belt system I was familiar with (it could still be fun; my snowblower had a similar arrangement - either on or neutral - and if you put it neutral, shifted to high speed and engaged go you needed to be ready to run!)
Handy on ground speed ptos for sure. The Wifes hybrid van has a similar "surge" under braking sometimes, and it's a very familiar (but very annoying) feeling. My Massey 35 has a two stage clutch. Great invention
Hi Guys.
Had a bicycle as a child that would run forwards going down hill but if you were on a hill going up it wouldn't roll backwards.
Anyone have one of these? Is the reach and clearance ok? Are they actually useful?
Or
