That's mos def a "why didn't I think of that?" Fantastic idea - I'd like to hear from real experience too.
I couldn't see the Subaru story you speak of, though. I'm very familiar with that case - EJ22, EJ25, and EZ30 - so I'd like to see the specifics.
Didn't want to give too much credit to that story as it reads like an ad more than a real experience (Facebook). Not saying the spark plug issue isn't real but rather the story wrapped around it.
Besides the suspect story the tool itself might be a good idea. I found there are much more expensive versions as well.
We have both that style and the Sakerplus 1/2" 2-in-1 ratchet set up
and the chain style you posted about.
Both seem to work well when working in hard to reach places, but then can be unwieldly in normal use, so they only get pulled out when needed.
Not sure how much torque the SakerPlus is rated for, they show it being used with high torque impact wrenches. I did have to take it apart, clean it out a bit and loctite the barrel to the head as it unthreaded the first time I used it.
Overall, yes good tool to have in the arsenal!
I have used a cheap pivoting magnetic thin wall socket like this guy for my Forester. I'm no expert and have only done it once so no proficiency but it worked. Pictures from the guy's blog.
I've never needed anything for plugs but a U-joint and extension on my OBWs (2.2, 2.5, 3.0) or Foresters (2.5). Sure, it's a PITA, like some other things with a boxer engine (just wait until you have to split the block to replace main bearings!), but doesn't necessitate special tools. I'd still like to try one of these things, though.
Been awhile, I have to say my most 'WOW,' factor purchase was a cheap digital noise level meter! Having done brass instruments for so long, and being a marksman, you'd think my hearing was poor; but I very often can clock where in a gear train needs the oil!
Working on noise reduction in my little space not only has improved my quality of life, but improved my surface finishes!
Yes, you can use a phone app or even a computer mic, but a dedicated little device I can put on the floor, inside of a cavity on my bench, etc, has really helped me track down all manner of harmonics in ways even I didn't think about before!
As I tell some of my band friends, being a musician makes you an excellent machinist, your machines will talk to you! I guess being able to pickout a single instrument in a performance means that at times, I disregard how much general static and waves are bouncing around when I am forming something. To reinforce this idea, here is a shot of a character from 'Les Triplettes de Belleville:'
1795203123294.pngAlways stuck with me. Have a great weekend everybody.
