I dont get the gag.
If I can get them in the break room unnoticed, I'll be long gone by the time they find them. The little Canada flag is a give away but they won't know what they are and unless they check cameras can't prove it was me
Americans take the piss out of me constantly so I take any chance I can to get mine 😀
They will think they are just tiny little pies for poor people who can't afford a real pie......
But if they actually try them, they will want more!!!
And then he gets to say no...... great balls of fun in that for the whole family. 😛 😉
To my southern brothers, I do apologize for my bad behavior, I was abandoned as a child and the wolves that raised me turned out to be a pack of rats. 😳
Or, use the 1/4” Hex drive handle of your choice with these:
GoFast also sells a nice compact hammer-impact handle separately or bundled with bits.
Yesterday I needed to tighten some 5mm socket cap screws inside a chunk of 2” square tubing. The screws were quite a depth in to the tubing, no way to use an allen key.
DeWALT angle drive to the rescue, very solid metal construction, great design, Holds regular 1/4” hex bits with very little projection, no wasted space.
$25 on Amazon or Rona.
I always wondered how well these work. Just yesterday we were trying to remove wood screws behind some wooden struts sitting on an angle. Ended up using vice grips holding a screw driver bit. Painful.
Prolly worth getting one of these.
Of course, if I do, I'll never need it again.
I looked that DeWalt a few years ago when I needed one, but decided on the Milescraft version:
Plastic body, but high Impact and the head is a little “shallower.” US$20 on Amazon. The 30 degree diecast one has a1/4” square drive, but came with a 1/4” to hex adapter (I can’t find one online). I’ve used both a couple of times in tight quarters.
I also have one of these:
US$36 on Amazon; used it once (couldn’t get a decent pic of mine).
I just grabbed a random image off Google to show the "ball style" handle. I don't actually own that exact Vessel tool.
I should have been more clear with my two separate thoughts: JIS tools, and Vessel JAW tooths and Ball grip. I don't like using my other non-ball style philip drivers as much. The ball also has a dimple on them for thumb so you get really good control without any fatique.
I liked the look of the Jaws bits, but the Vessel website is almost as hard to navigate as Zoro. When I searched for the bits, I was taken to their catalog, where I found these:
But I couldn't find those item numbers on the website. Zoro (as always when searching) was worse. In the end, I happened across these on Amazon, along with some JIS bits from the same vendor:
3" Anti-Slip PH2 (Laser Etched, so not as deep as the Jaws), 3" JIS 1, 2 & 3 and 4" JIS 1, 2 & 3; "TiWan Steel"
