Almost everything I work on uses standard hardware, everything I work on at my main job is standard . I do have a few exceptions now like the lathe, motorcycle and couple of other things. So I recently had to work on my Tacoma because the shop I usually take the truck to was booked up for a week. The shop that works on my truck has a labour rate that is a bargain. They are also very efficient. They do in an hour what takes me the morning. They told me to take a crack at fixing it and if I got stuck he would send someone over. I work on a lot of things but prefer not to work on modern automobiles.
Anyway I was cringing because here in the land of rust I was pretty sure I would round off at least a few nuts and bolts. I got the truck repaired and reinstalled some semi rounded hardware because I don't have much metric hardware here. I decided it was time to replace my early 1990's sears metric sockets with something better. So my tool I waited to long to acquire is new metric sockets in 1/4 and 3/8 drive. The sockets I use the most at work are snap on. For the price of 1.5 snap on deep sockets I bought a 28 piece set of 1/4 drive metric sockets. They use something they call wavedrive to avoid rounding off the corners of the fasteners. From the little I have used them since they arrived they are fantastic. Sold by a company called Capri. I have also bought Tekton sockets recently in standard and was happy with those also.
Per Amazon AI:
Capri Tools 1/4 in. Drive 6-Point Socket Set, and WaveDrive is one of its standout features.
WaveDrive – What It Does:
• Grips fasteners more tightly than traditional 6-point socket designs
• Prevents fastener rounding – the wave-shaped contact points apply force to the flat sides of a fastener (not the corners), reducing the chance of stripping or rounding the bolt/nut
• Gives you more leverage, making it easier to break loose stubborn or corroded fasteners
• Works especially well on worn or damaged fasteners where a standard socket might slip.
In short: WaveDrive reduces the risk of damaging fasteners during heavy-duty or precision work — which is particularly useful for machining and automotive applications.
Back in the 1960's Snap-On bought the Utica tool company to get the patent on what Snap-On later called the Flank Drive which they used in all their sockets and wrenches. The flank drive consisted of a relief each corner of the hex that put pressure on the nut or bolt head away from the edge of the hex making it less likely to round the hex off. Capri's Wave Drive looks to work exactly the same.
Per Amazon AI:
Yeah I'm familiar with that system. If I recall right, snap on invented and patented it. Their patents eventually ran out and now everyone seems to have the system under their own name. It's not perfect though. There have been many failures of aircraft fasteners. Some people think that it's caused by the flank or wave drive type tools. It happens on the reduced dimension nuts that are common in aviation.
JIS tools for my Japanese motorcycles. Ruined a few stubborn screws before getting the JIS screw drivers.
Vessel has their "JAWS" tips that really help, and I like their palm ball ergonomics.
Yes, I've discussed JIS drivers on here before. After a bit of time with them, I have decided that they are vastly better than Philips. No contest.
Per the Vessel website, this is a #2 Phillips:
I just grabbed a random image off Google to show the "ball style" handle. I don't actually own that exact Vessel tool.
I should have been more clear with my two separate thoughts: JIS tools, and Vessel JAW tooths and Ball grip. I don't like using my other non-ball style philip drivers as much. The ball also has a dimple on them for thumb so you get really good control without any fatique.
Agree, you can get a more secure grip on a ball and can apply “inward” pressure while unloosening.
Most of my most used tools were the first few large purchases that I invested in for growth. I started with a cheep Everlast mig welder, but later moved to a fairly affordable Miller multiprocess welder. The access to tig welding gave me much more freedom to welding both thich and thin steel and stainless steel. The welder I have now (Miller multimatic 220) was not cheap and it isn't used as much as before.
I'd say my plasma cutter and CNC plasma table have always been the most useful tools. Plasma cutting far outruns oxy fuel cutting and CNC jet cutting machines are easy to learn and use.
Outside of the frequency that each tool is used, my fiber laser gave me the most excitement by the gateway towards creativity that it opened.
unloosening
Errr, ummm, what exactly does that word mean Chazz? Is that some weird quality of things from Mars or Venus? Or some other thing we are equally unfamiliar with......
You have been into the crackers again haven't you!
It's American speak for tighten....... 😉
Nope: it’s a Joe Pie-ism; kind of like a Yogi Berra-ism, but not:
In just about every Joe Pie YT video he mentions “unloosening” something instead of loosening it.
I mentioned butter tarts to the guys in Ohio the other day and his little head was confused. I should see if Walmart has a six pack to take down. Or Nanaimo bars. Maybe I'll get them a card too, from Canada with love, and leave it in the break room when nobody's looking
That’s more like Scrapple (or going to the Liver Mush Festival in North Carolina), or maybe Stuckey’s:
Don't forget the Uranus Fudge Factory
We have peameal bacon, pork in a brine and coated in corn meal. Size of a small pork roast but sliced like bread. Wonder how it compares
I've been to the azalea festival in Wilmington, if that counts
