I was going to ask the same thing. While it's a bit annoying I think i could change mine in 3 minutes to any position.30 minutes to change belt positions?
How can it take that long?
I'm curious about the diameters of the pulleys on @YYCHobbyMachinist machine
On Monday, I can come over and show you a few setups.
Cannot for the life of me figure how to indicate off the fixed jaw without resorting to using a mirror to read the DI.
Best is still to use the DTI on the fixed jaw.
Also (see Rudy picture) try using double washer under the bolt head. You will soon encounter having the jaw set perfectly aligned when vise slightly loose, but the tightening action makes it go out of whack again. Part of that is just experience, going back & forth progressive tightening & checking, but double washers provide a bit of torque slip. I think there are more sophisticated washers specifically for this, but anyways might help.
