No worries!Don't have anything large enough to measure these pulleys with🙁
Ya but the milling looks good.The NUTS of SHAME..... LOL
I got the T part right but sure blew locating the holes. No very good with scribing and center punching that's for sure.
A center finder will com in so handy!
I’m not sure what sort of edge finder you’re referring to. I have one that I’ve never used that lights up when you touch an edge. I think it would be wise to touch off, rotate the spindle 180 degrees and touch off again. This compensates for any bend in the indicator.
when I need something better than close enough I use an endmill and a piece of paper.
Why would you need to use it at 800 rpm? I wouldn't think it would not hurt it tho.Woha, I didn't realize those electronic ones were $50!
I have one of these https://www.busybeetools.com/products/edge-and-centre-finder-1-2in-dia.html and it's been working fine for me on my variable speed mini. The question is can I use it at 800 RPM with out destroying it?
Ah yes the fun of belt changes. Yes I think it would be okay but I probably have less milling experience than you! Matter of fact I think those finders probably work better at high speed than real low. Let's let someone else be the guide on this one.Just to avoid a belt change LOL. So you think it's ok at 800 RPM or not?
Looks like my holes are off a bit 😡
if they are functional - job done.
Maybe an issue with backlash? Or not compensating for it? (Probably not the case, as you state that you had scribe lines...). If you make another set, mill the “T” first and then put in the holes - gives you a chance to “cheat“ them into center. Meaning: use a spot drill and just put a dimple, check for center by measuring edge-to-dimple from both sides. If it is off, move half the difference. Re-dimple. Check again. Drill your holes.
The stock was a little trapezoidal
As I've stated before, I abhor belt changes on my machine and can commiserate with Craig's 3 post in less than a week of first using his machine on belt change hesitations.Just to avoid a belt change LOL. So you think it's ok at 800 RPM or not?
Basically I avoided belt changes by turning my mill at about 2-300 rpm no mater what size tool I use or what material I'm cutting. Slows down my jobs a bit all the time but I just cant see taking 30 minutes to change belt positions to save 10 minutes on a 20 minute job and then 30 minutes to change back again...and I notice a significant lessening of turning HSS endmills blue mid-job LOL.
Craig, I checked my mill speed chart and it is the same as yours that is in the photo.
