zipped and attached!Send me the file, I'll give it a whirl.
With the Bambu slicer it shows a print time of 2:26 at regular speed. I've got the printer doing some gridfinity bins right now but I'll feed it through later. It has to be printing before I can change the print speed to Sport or Ludicrous.Send me the file, I'll give it a whirl.
The print speed options are Silent, Standard, Sport and Ludicrous.I was gunna put a laughing emojii on that but then realized you could be serious or joking?
They can be changed only once the print has begun. Sport is 25% faster and Ludicrous is 66% faster.
The other way to change print speed is to tweak the travel speed in the slicer in terms of mm/s travel.
I didn't name the options, I just press the buttons![]()
That's Ludicrous !!!!Ludicrous mode shows 1:29 for print time. I'll run one off to see what the quality is like. Depending on the model, Ludicrous mode can be messy.
Also turned out to be a birds' nest. I've changed some of the presets for PETG and am giving it another try.That's Ludicrous !!!!
Here we go again. More magic voodoo to get it to work and yet another reason I might never get a 3D printer......
Dude, it's just reverse machining. Speeds and feeds, heating and cooling. Additive machining instead of subtractive machining. I have more than a little confidence that you would find it pretty simple. Always a few rabbit holes to fall into of course but you seem familiar with rabbit holesAlso turned out to be a birds' nest. I've changed some of the presets for PETG and am giving it another try.
..... Pretty sure I saw a big hairy, ape-like fella holding hands with Alice and skipping their way to Wonderland...... Always a few rabbit holes to fall into of course but you seem familiar with rabbit holes![]()
240 nozzle, feed 60. never fails. gluestick and watch the first layer... prusa or whatever....Also turned out to be a birds' nest. I've changed some of the presets for PETG and am giving it another try.
send me your ideas, I can make them materialize...Here we go again. More magic voodoo to get it to work and yet another reason I might never get a 3D printer......
Dude, it's just reverse machining. Speeds and feeds, heating and cooling. Additive machining instead of subtractive machining. I have more than a little confidence that you would find it pretty simple. Always a few rabbit holes to fall into of course but you seem familiar with rabbit holes![]()
..... Pretty sure I saw a big hairy, ape-like fella holding hands with Alice and skipping their way to Wonderland.....![]()
