  • Meetup Notice: Several Regions have held meetups already, but others are being planned or are evaluating the interest. The Ontario GTA West area meetup is planned for Saturday April 26th at Greasemonkeys shop in Aylmer Ontario. If you are interested and haven’t signed up yet, visit the following thread: https://canadianhobbymetalworkers.com/threads/announcing-the-2025-ontario-meetup-april-26-in-aylmer.14427/ Arbutus has also explored interest in a Fraser Valley meetup but it seems members either missed his thread or had other plans. Let him know if you are interested in a meetup later in the year by posting on the following thread: https://canadianhobbymetalworkers.com/threads/vancouver-fraser-valley-meetup.14754/ Slowpoke is trying to pull together an Ottawa area meetup later this summer. No date has been selected yet, so let him know if you are interested here: https://canadianhobbymetalworkers.com/threads/ottawa-area-bbq-and-swap-meet-this-summer.14487/ We are not aware of any other meetups being planned this year. If you are interested in doing something in your area, let everyone know and make it happen! Meetups are a great way to make new machining friends and get hands on help in your area. Don’t be shy, sign up and come, or plan your own meetup!
Pallets of 4140
6.75" solid:
1 PC-619 LB
4140/4142 HR ANN BAR ASTM A322
6-3/4 RD X 5'1.0" ( 61.0") REMNANT
$1714.50 / crop
Sell MS a one of your 7 logs & buy a brand new bandsaw with the proceeds haha
A friend of mine has some big iron to cut & no band saw at all. He apparently found a shop with a big ass saw to do it pretty reasonably. They basically said leave it for a week if it wasn't rush & charged him an hour of shop time, so he got the segments he required. But that was back in the hungry days, not sure if that can be replicated. If you had a batch of cutting to do, might save wear & tear on the smaller saws, but I don't really have a feel for what they are capable of on this stuff.
I would think such a simple request in this market would yield positive results, shops are hurting after all and "you need the bread to support the butter"
I finished my cut. The kerfs weren't right on so I had to pry the last bit apart. If I ever do this again I'll build a jig to hold it nice and square and allow the piece to be rotated without losing alignment. Best bet would be to find someone with a bigger saw.
Yes, lots of cutting oil. It probably took 2 hours total, including the time to free the stuck blade.
I had to reverse the fixed jaw on the vise to get the log to fit. The final cut was <1/4" out of alignment but I was able to pry the kerf open to finish the cut.
I've fiddled around with the tri-bearing setup on my little saw. You loosen a nut, turn the cam axle, that moves the bearing in & out. It cant be too tight & it cant be too loose on either side of blade. Anyway, yes, I could see where even a bit of misalignment or slight tension difference on one side could drift the blade cut path slightly so the cuts might not meet exactly in the middle. And probably a skinny blade might drift more.
There is a really cool video series posted on Oxtool called making flat lapping plates using similar log slices. What they call the 3-plate method. But those are cast iron, which I suspect is the proper material because its more stable for this particular purpose.
I think it was more a matter of the vise fixed jaw not being perfectly aligned.
Hey I have a 12x20 bandsaw and if you want to cut some stock on it i don't mind hanging around while you cut it. I just ordered a lenox classic blade from TS it will be here in a couple of days. I do have an engine picker you could use to get the material onto the saw. Inbox me if you want to use it.
Lapping plates are made of cast iron because they are porous, and hold onto the lapping medium. Toolmaker plates are made by lapping and are made of hardened steel. 4140 can be surface ground and lapped like any tool steel.
Hi I made a quick study of band saw performance. I used the starrett guide as linked below. Alex scoffed at their performance numbers. They think you can cut a 4" round in 1 minute in ideal conditions. My experience with my old band saw was more like 2-10 hours depending on how much fussing with the saw I had to do. I'm not sure yet what my 7x12 will do. Anyone with professional saw hydmech etc or other big tools care to chime in with observed performance? Anyone with better performance on their home saw care to report?
Yes I've heard that about CI - its porosity is desirable for holding compound. But many soft laps like copper & brass also exist as they imbed compound. So maybe CI has additional advantages - hardness. dimensional stability, tool wear? Re 4140, I assume you mean after its been hardened it can be ground & lapped? I don't think its any more dimensionally in annealed state than regular or tool steels is it?
No it's quite soft see (pic1; from my handle less hammer used to free my blade when having to rotate the piece)
I used my propoint (pic2) with my new unused all blades blade 52 x 1/2 x .025 6-10 TPI cutting 4" took about 10 minutes no cutting fluid or coolant of any kind (pic 3; cut marks including pull out and no heat discolouration) but I was messing around with bunjies (pic4) and stalled the saw once (some saftey thing) I could likely bring that time down to 8-9 minutes MAYBE.
I'm out of town tomorrow morning for a few days so I won't be trying until I get back - this test fascinates me!
Well I guess I'll get involved in "SAW WARS" too. I got a great deal on a new 7 x 12" saw at KMS yesterday. I set it up last evening and left it on the slowest speed. It sliced through a 4" log in 11 minutes. Virtually no heat in the 1" piece I sliced off. I'll do more tests later including timing my 4 X 6" saw on the same job. I'll be selling the 4 X 6" if anyone is interested.
John
