MooseMeat
I'll add the ferrite rings after the vfd out to the motor, I'll try wrapping the tach cable as well , my computer is about 8ft away and has no issues, the tach cable did not come shielded but that's an easy fix. I did put a filter before the vfd, basically copying Clougs42's setup other than the ferrite rings which I had to order.Hi MM, Guys,
The Tach should be wired before the VFD and should be using shielded cable. The ferrite rings in the tach lead should help as will a capacitor of about 1000 pf wired across the tach. There should also be a mains filter either built into the VFD or in the mains supply directly before it. There should also be a mains earth terminal that should be used on the VFD and continued to the lathe metalwork.
VFD's are basically very electrically noisy things, its a function of how they work. In Europe it is mandated that things like VFD's, have mains filters built in as have many other electrical appliances.
cheers and thanks
