I gave you the cheat in the pics.....😉 that's two guesses
Magnet is loose?
nopeMagnet is loose?
nopeI favor a two layer ABS pipe capture for the magnet. The magnet sits in a hole in the bottom layer and the top layer captures it and holds it in place.
nopeYou read the instructions and wired it correctly. 😀
it's actually in the pictures
it's actually crazy glued to the plastic ring,All I see in your pictures is a loose magnet.
Maybe get your wives to look, just saying..')All I see in your pictures is a loose magnet.
"My wife wouldn't know a wire from a zip tie."My wife wouldn't know a wire from a zip tie.
Cable vibrating on the housing? That isn't likely to be a problem on its own, but maybe it is moving the sensor?
I dunno @MooseMeat, you are there to see what isn't obvious to me in a photo.
Btw, I agree with everything @slow-poke suggests. They duplicate some of my suggestions but it's always good to hear different versions.
Anyways, glad you got this one figured out.
HI MM,wrapping the sensor wire with tinfoil made no difference as did a different circuit, did the drill test with the vfd on but the motor not running and it worked fine 225 rpm on the drill, the second I start the motor the problem shows up.
SEE THEM DAM GREEN RINGS? 😉 the ferrites killed the problem.
When I tried the tack on a different circuit I moved the wires as far away as they would reach and same problem occurred, I can shield the output cable but will have to get some proper shielding.Hmmmm. First he tells us not to look at the VFD system. Then he tells us to look at the ferrite rings in the VFD system...... Your wife must be a Saint!
Those ferrite rings might have very well killed the problem. But it looks like they are on the output to the motor. That is NOT a good idea. If the motor outputs are creating a problem, you should not try to reduce the problem. Instead you should try to isolate the problem noise so it can't affect anything else. The reason for this is that the VFD needs to see the full signal to the motor - not one that is filtered. Otherwise, it can't accurately measure what the motor is doing.
You can accomplish the same result by shielding the output cable. That doesn't stop the noise from happening. It just stops other devices from seeing it. Tin foil will not suffice.
Also, I would run your tach wires as far away from the motor output cables as you can get them. They look very close (too close) the way they are there.
I used braided shielded cable to my motor. That's probably overkill, but like your system probably has, mine had scary levels of noise on the outputs. I didn't want to risk seeing any of that noise reach any other devices in the area.
The braid mesh and the shield are both tied to ground at the VFD Ground terminal nearest the output. They are not connected to the motor and just float at that end. However, the motor is grounded with a separate ground wire inside the cable shielding.
