BaronJ
Hi Guys,
I've spent some time reading through that link, most interesting.
Using the tramming gauge that I made I determined that the mill head nodded about 4 or 4.5 Thou.
Since correcting the nod on these mills is quite a major undertaking, there are four bolts that secure the column , they are also thread locked as well. I had to use a rattle gun to break them free after using a propane torch on the bolt heads.
Having now got all four bolts free and was able to move the column enough to clean the crap of the joining surfaces, I discovered that I could fit all four bolts back and tilt the column complete with the head enough to be able to fit a shim in between the bolts.
I had calculated that I would need a shim about 5 Thou thick. In fact I found that a two Thou shim got the head within 1/2 a Thou of true. Surprisingly the tram in the table direction barely changed. I did readjust it and rechecked the nod, that didn't change either.
Whilst I think on, I do have a 10" inch brake rotor that I have used to quickly check the tram.
This is the right hand side head stop.
And this is the left hand side head stop.
