here are a few pics of the first mill job,
I prolly would not have used a face mill, but it's not a fussy job. If it works, it works!
Good thinking to remove the metal from the bottom of the tool. My first time, I removed it from the top. That was a mistake.
What is your tool post size? They do make tall tool holders for AXA, BXA, and CXA. this basically increases your tool holders to the next size up. Mine being BXA, takes 5/8" tools. The tall BXA holders take 3/4" tools.
I made a dual meter device to set the tram on my mill.
I'll readily confess that I don't think an indicator setup (either 1, 2, or 3) is nearly as useful as a tramming plate. A good plate makes the whole tramming process trivial.
I made a tramming fixture from a 12" OD brake disk. Brake discs are made to very exacting tolerances in order to prevent brake pedal throb and pulsing. A brake disc mounted
ABOVE THE VISE, provides the following advantages:
1. You don't have to remove the vise to check or adjust tram.
2. You don't have to deal with T-slot incontinuities. You can just sweep smoothly and continuously.
3. But most importantly of all, a round disk provides a sweep range of 360 degrees extending the travel not just to both sides, but also behind and in front of the table making nod adjustments easy.
All you need is an inexpensive brake disk and 3 precision blocks - 2-4-6 blocks work great. You can buy them or make your own if you have a surface grinder (that's what I did). You can also make them on a mill but only if it's already trammed!
The blocks are placed on the table with two on one side of the vise front and back, and one in the middle on the other side. This allows the disk to be mounted above the vise.
Now you have a perfect surface that is perfectly parallel to your table on which to tram the mill head. Lots of members use two indicators and I made a fixture for 3 so I can tram without sweeping. But you can sweep if you want. One indicator is easy with the tramming plate. Two is easier, and 3 is easiest of all.
Here is a great thread from the past with lots of math, drawings, and ideas!
Thread 'Spindle square'
https://canadianhobbymetalworkers.com/threads/spindle-square.4225/
Btw,
@BaronJ - I don't recinme
