Nope. Buy find Waldo in this one...What? No partridge?
I don't like stepper motors[; their noise and lost torque at higher RPM. I had DC Brushed Servos with UHU HP controllers that worked really well until I noticed lost motion on X. The X motor also never got as hot as the Y motor. Final investigation revealed the X motor had twice the resistance in the windings compared to the Y motor. Likely a 180VDC motor and not a 90VDC motor but labelled incorrectly. Automation Technologies wouldn't replace it as it was already many years old before I ever installed it. Cost of a replacement 90V motor was more than ordering from Bergerda in China.Looking good!
My new lathe X-axis cover is "boxy" in comparison to yours.
I decided to go direct drive for X & Y on the mill.
Servo power, 400W, or smaller?
Backlash on the Z axis?
Taa Daa! I probably should have cut him out of the white background and hidden him better.
I'm with you on the servo vs. Stepper, both my mill and lathe are 100% ac servo and they have no problem moving at crazy speeds near silently. Drives are powered by 220-240Vac, I'm using Yaskawa for the lathe, and they are very easy to tune.I don't like stepper motors[; their noise and lost torque at higher RPM. I had DC Brushed Servos with UHU HP controllers that worked really well until I noticed lost motion on X. The X motor also never got as hot as the Y motor. Final investigation revealed the X motor had twice the resistance in the windings compared to the Y motor. Likely a 180VDC motor and not a 90VDC motor but labelled incorrectly. Automation Technologies wouldn't replace it as it was already many years old before I ever installed it. Cost of a replacement 90V motor was more than ordering from Bergerda in China.
Replacing the 1100 oz-in stepper on the knee with a 750W motor also upped my Z speed to a scary 120 IPM from max 25 IPM. And it's so quiet now.
Oh yes and 400W on X and Y with 3:1 and 4:1 ratio.
The DC servos were great and worked well. Or so I thought. The DRO reported that a return to a specific position started drifting. Yet the driver never reported missing steps. As in move say 2000 steps and it didn't move 2000 steps according to the DRO yet the drive didn't report the issue.I'm with you on the servo vs. Stepper, both my mill and lathe are 100% ac servo and they have no problem moving at crazy speeds near silently. Drives are powered by 220-240Vac, I'm using Yaskawa for the lathe, and they are very easy to tune.
I finally found some time to paint my Utilathe.From what I have read many of the polyurethane paints cure slowly.
I decided to try this one, it's supposed to cure quickly, 15 minutes to the touch. I will let you know if I ever find some time to use it.
View attachment 68606High Performance Command | Benjamin Moore
Command® is an extremely durable single-component, multi-substrate solution that helps you save time and tackle multiple jobs with confidence.www.benjaminmoore.com
Way back when I first bought the paint it dried as per the can label. Now it's really old and takes forever to cure.I finally found some time to paint my Utilathe.
Benjamin Moore has yet to disappoint, drys to the touch in 15-20 minutes, apparently cures hard enough for forklift traffic in 24 hours. Goes on like typical B.M. I can't comment on durability yet, however first impressions are excellent.
B.M. Might be a bit more expensive, but typically saves you a bunch of time when applying it.
So if I follow the alarm report when servo fails close-loop is not working?The DC servos were great and worked well. Or so I thought. The DRO reported that a return to a specific position started drifting. Yet the driver never reported missing steps. As in move say 2000 steps and it didn't move 2000 steps according to the DRO yet the drive didn't report the issue.
If was only after a milling operation had a new cut at a deeper depth wasn't in line with the previous ones. Swapping the controller didn't help while swapping the motors fixed the problem. That's when I noticed the working motor got hotter because of course to hold position a certain amount of current had to flow through the windings. Really too bad as I bought 4 of the bare PC boards and parts and assembled and tested two of them. The other two are almost complete.
It's an HP-UHU DC Servo Drive board.So if I follow the alarm report when servo fails close-loop is not working?
Who's board is that?
Or is the board generating the alarm and the CNC control software ignoring it?
No such thing as a hole in the wrong place. It must be a ventilation shaft.That and center punching and drilling one hole in the wrong place.
So the wrench hangers are now permanently mounted.
The open end wrench is for two different size bolts on the mill.Why two wrenches John? And why not a rachet wrench?
I only have one wrench on my mill - a 3/4" open end rachet wrench. The rachet make turning more than a few degrees easy. The direction is indicated by where the jaws point. It operates my drawbar and my vise.
