Follow Rest for Standard Modern
That's kind of what my right angle plate idea was also trying to address. However it only works if you have T slots in the cross slide (which thankfully I do have).
The typical follow rest are robust chunks of CI, no issue there. But the whole system relies on 2 bolts screwed horizontally into cross slide. Supposedly it should stay tight & secure but the cutting force is acting to rotate the steady body against these bolts.... Anyways I figure if I had to make one, an adjoining integral right angle plate, bolted vertically into the T's would provide better support. And if one designed it right, ideally allow for different mount positions. I want to make myself a micro version for turning very thin aspect ratio stock.
There seemed to still be too much flex. So, version 4 &5.
Version 4 had 0.005" deflection, but then I couldn't move the cross-slide close enough, so I had to cut out some sections. Saying that, deflection is at 0.006".
Why are you measuring the deflection of the wood mock up? You're making the final product from steel plate are you not?
While wood can be quite non-homogenous, it's still a good proxy. The numbers will usually scale and its easy enough to modify. The shape is what can drive you nuts by distorting in places you didn't expect.
I like @thestelster s approach to this. He will learn a lot by playing with a wooden prototype before committing to machining a piece of steel. But ya, the final steel part won't deform like the wood does. However it will be a much better final result than it would have been by going straight to steel.
I started making the follow rest the other day. I'm planning on using the basic design as my wood mock-up, plus suggestions from our members.
The frame is a 1" thick piece of hot rolled steel slab.
Started on the bandsaw, of course this piece is pretty big for the saw, do had to clamp it on an angle.
Now to make the hole. 3", in diameter. I don't have annular cutters, so this took a little while. Spot drill, 1/4" drill, 1/2", 1". I switched from the 5C collet chuck, to the three jaw, because there was going to be a lot of torque when using the 3" hole saw.
I started with a 2 1/4" hole saw, just to see if that would work. It was really slow going. .020" pecks, because the teeth were getting clogged, even with compressed air or cutting fluid. Perhaps if I had high pressure flood cooling it would work, but I don't.
Then switched to the 3" holesaw. Much trepidation since not all the teeth would be engaged in the material.
I needn't have worried, it actually allowed the chips to evacute the cut and it went very quickly with power feed.
I also used the QCTP to hold a hunk of steel to support the slab from flexing.
Now to make the hole. 3", in diameter. I don't have annular cutters, so this took a little while. .
I would have ordered an annular cutter...... Most of them that I have seen use a 3/4" Weldon Shank.
Another alternative would be a boring bar mounted in the chuck with an axial bit to use like reverse trepanning.
Making the slots for the support fingers. 1" wide, 1/2" depth. First using a 1" HSS roughing endmill. 0.400" depth cut (I should have taken the whole .5", it cut so nicely). 350rpm @ ~3ipm. Then used the finish endmill to clean up the sides.
Annular cutters are on my wish list! But, honestly, if I had gone straight to the 3" holesaw, I would have been done in 5minutes!! Having the holesaw off the side of the material, clearing all the shavings made quick work!
If you are looking to add stiffness without bulk or wt (lots) add a flat bar to make it "T" shape to the top/back edge. Taper in width wise to from the nose (no bending moment here) to further back and down (maximum bending moment here).
Lets you avoid interference issues yet have the performance you want.
Thank you. My intent is to stiffen it up, but I havent decided on the final shape of the follow rest. I would like to make the rear section in an arc, and I don't think it will compromise the rigidity. Plus I have to take into consideration the placement of the x-axis scale, taper-turning attachment, tailstock, and QCTP.
I now have to make the support fingers. I've been trying to decide what best material to make them from, and I've been scouring the internet to find an answer. And the consensus is....it depends! Of course!
Bronze, cast iron, hardened steel, carbide, Teflon.....
Maybe make a set with removable pads of the different materials.
HELP!!! Any advice will be most appreciated.
Make the ones you think you will use the most, you can always make multiple sets of different materials
Are bronze fingers not the most common that come with factory made rests? That's probabaly what I would go with unless you had some specific reason for another material type
Yes, bronze seems to be the multi-pupose material, but at almost $200 worth of material needed, it's a little dear. That's why I'm contemplating steel fingers, with replaceable tips.
Seems like depending on supplier there is more bronze alloy selection in round vs rectangular. But it might be spendy to make the whole finger out of bronze when only the tip is in contact.
Most of the replaceable tips I see are integrated into round fingers with kind of a tenon boss into a hole in the finger. But assume your fingers are rectangular? Show us what you have in mind. I'm sure there is a viable method, just have to figure out the most viable.
Exactly!
Yes, rectangular.
I'm not sure of attachment yet, Threaded, dovetail, pin, securing screw. I'm making the finger bodies now, and I'll think it through as I make them, and get suggestions.
