Do they need a junction box at each location?
usually they have an electronic ballast in a box built in for wiring and supplying power to the LEDs. You make the junction there.
Are you planning on doing the drywall? If you are, and haven’t done much drywall before, there’s a few tricks that make it a lot easierI'm getting a new 200 amp service in the garage. That should be useful. The house will be fed from that panel. There will be a 100 amp panel in the house.
I should be good for a while in the garage. 🙂 Just need to figure out what to install before I drywall. Presently running super small machines in my basement shop, but I see all the toys you gents have and well envy starts to build. 😉
I've been doing some drywalling the last few days and all I can say is that it confirms that I was right to become an accountant!Are you planning on doing the drywall? If you are, and haven’t done much drywall before, there’s a few tricks that make it a lot easier
It’s easy, with the right tools and some experience. Panel lifter, Dremel with a drywall bit, drywall rasp, drywall saw and a T square. Do the ceiling first then the walls. Try to get as many factory edges to mate. Hang a sheet, then use the Dremel to cut out any electrical boxes or fixtures. Then finish screwing it down. The more time you spend doing a good job hanging the sheets, makes the tapers job 100x easierI've been doing some drywalling the last few days and all I can say is that it confirms that I was right to become an accountant!
Yeah, it is the mudding part I suck at. My late brother was really good at it and used to help me out when I needed it. He wasn't a great teacher, though, and I never learned myself.It’s easy, with the right tools and some experience. Panel lifter, Dremel with a drywall bit, drywall rasp, drywall saw and a T square. Do the ceiling first then the walls. Try to get as many factory edges to mate. Hang a sheet, then use the Dremel to cut out any electrical boxes or fixtures. Then finish screwing it down. The more time you spend doing a good job hanging the sheets, makes the tapers job 100x easier
Sometimes I use my shop vac with my CNC mill in the basement. I noticed if the shop vac and the mill are on the same circuit I can have the
mill (CNC) miss random steps. I always use two separate circuits now when I use the two together.
I'm pretty sure it is a noise issue. I have a second vacuum that does not cause the issue.(Yet...lol) The larger shop vac seems to be the only one that does it. (could be a voltage drop with the larger unit.)This would terrify me. Nice that you noticed it though. I think most of us would mess up a thousand parts before we realized what was happening.
Most likely you are either dropping voltage or getting noise on the circuit. A bigger gauge wire, shorter run, and sometimes just the quality of the wiring connections would fix the former and a line filter would fix the latter.
In any event, I'd be trying to find and fix the root problem.
