and here I have a setup for milling across stock that I can rotate on the vertical table. I just set this up for the camera, but the milling can be done perpendicular, longitudinally, or at an angle to the stock to produce different patterns
LMS 3990 Mini-Mill with a 2" Riser (and like the Mini-Lathe, a number of updates). When I win the lottery I'll upgrade to a PM (probably) Bench Mill.This thread is a poll to determine the range of mills that our members have. If the poll questions are not adequate, please provide additional comments below.
Bandit, the boring mill is in the middle. That’s what holds the concrete floor down.🙂Teeth are abit course for metal, "Martin w". That would be a bit noisy in the shop! Haven't seen one of them saws for a few years. What did you put on the other side of the shop to balance the boring mill?
And then they invented the chainsaw, much easier to fall trees with😛Yeah the old Ottawa doesn’t do so well on steel,! People were strapping, hardy and rugged back in the day to use that.
Martin
