Daily Shop Improvement
Bit of a long day but the end result is worth it.
I wired in four 120v outlets and a 40A 240v plug for the welder.
All that’s left to do is fill in the space above the panel and paint.
Then all the interior wall done
I still have to run some outlets in the wall
but those I have to do with conduit as there’s no overhead access due to the beam.
Nice. One thing about plywood is its tough. You can screw & hang legitimate stuff to it.
You probably mentioned this a many moons ago, but what kind of (I assume TIG) welder are you plugging into the 40A & have you had any issues approaching the max?
oh crap it says right there in your profile. duh
Yup, it’s a Primeweld 225 AC/DC TIG.
I’ve only just installed the 40A circuit so I have no idea what it’s like at max amperage.
I will say that I could squeeze 85A out of a 15A 120v circuit so 225A on 240v 40A should be doable.
Specs call for a 50A breaker but none of the folks who I know are running 50A and it maxes out just fine.
Put in an hour or so after work and got the beginnings of the shelving up.
Reusing the 5/8 ply from the freestanding shelves, 2x2 clear along the wall, 3/4” metal strapping down from the roof joists wrapped under the front edge of the plywood. Fastened with 5/8” wood screws.
Bit hard d to see the single strap in place near the left end.
Strong enough to hold me doing a chin up. Just one ;)
Wow I wish I could do a chin up.
I'll bet my Shamu like body can break that shelf with a chin up. Probably crack the floor when I fall too. Is there a prize?
Ok now I have to clean up the pumpkin tart I just coughed onto table!
Well done! :D
Plus 1 for loving plywood on the walls for easy hanging stuff. I’m not a huge fan of pegboard but it works.
No making fun of me for labelling my bolt bin :D
I’m going to look at pressure washers
My Sons mother in law bought a broom and stuck it in the corner of their porch I told him to put up a No Parking sign. :)
Yet more organizing happened today.
Got rid of a huge Ridgid shop vac freeing up four sq ft. Good riddance!
I have a stainless Husky vac which is much more manageable.
I no longer have any big plastic totes on the floor. From three totes to zero!
Had some time tonight to get the tailgate changed out. I’m digging it, I think that looks sexy.
There’s a spring inside of these tailgates, which I didn’t know. My old one was hard to close, turns out my old tailgate spring was broken. I guess it’s like a torsion spring, when you open the gate it puts tension in the spring to assist you closing it. Night and day difference in opening and closing it.
