Tom O
Apparently Hop sing died in the eighty’s.Look closely for the wiring mixup that hopsing made. View attachment 20649
Google Search
www.google.ca
Ad the same problem changed this parts work perfectly after
You can bye this new for 22.00$
Sorry dad , It wasn't under power , simply sitting on the bench , making a continuity test to see if the contacts were intact .DUDE what did I tell you about manually activating contactors? You can't rely on that method for testing circuits.
Ah I haven't looked but is that connection also reversed so that the fuse is after the contactor coil?
I was testing them with my ohmmeter where the wires connect to the terminal strip , I've done it a couple of times and again today when I put the switches back in the spot where they are mounted , just to confirm they were doing what they are supposed to do. There are notes on the hand drawn schematic that shows the low voltage control circuits , showing which terminals make contact in which position .Switch testing can be looked at the same as contactor testing. They both have contacts which are usually the mode of failure. They can be bypassed with jumpers . If it works, theres your problem.
If only Busy Bee stocked some of these , of course I already know the response I'll get from the local store , same old ...... "we can not stock parts for a machine this old"A set of contacts can test fine OHM wise, but be pitted and not capable of passing enough current to energize the load....same way as automotive stuff.
I have seen it hundreds of times in my trade.I prefer a continuity test for this... and it is very unlikely that a contacts that pass a continuity test will not pass enough current at 30v to energize a coil. The pickup voltage is far less than that IIRC
What i will do is , tomorrow , I'll make up a set of jumper wires and bypass the switch by removing it from the circuit and jumping the terminals to select a direction .I have seen it hundreds of times in my trade.
But so as to not confuse this thread further I'm done with commenting further on this thread.
Yeah I couldn't help but jump back in because I've also been helping via DMs. Thanks for the reminder. I'm unwatching this thread now
