Other Basic Electronics, Multimeters, & Oscilloscopes
This thread is about basic electrical, electronics, Multimeters, and Oscilloscopes. It is an outcome of interest that various members have expressed about these subjects.
@Janger , @Johnwa , and @kevin.decelles have all recently obtained a starter Oscilloscope so I think the timing is good for a thread like this.
The primary resource will be a book (available on Amazon in paper or kindle) called Electronics for Dummies by Kathleen Shamieh. The book isn't a requirement, but it always helps to have a reference of some kind to facilitate discussion. Other references might get added as the thread progresses.
I'm not picturing this thread as a course, just a good place to ask questions, find answers, and share knowledge and experience about basic electrical knowledge and testing.
As always, a good time and lots of great jokes are expected!
I just placed an order for one of the 1014D scopes. It should be here Friday. I was considering a Rigol 100Mhz scope for almost twice the price but I just can't justify the extra cost.
You won't be disappointed. The 1014D is a lot of scope for just under $200. Don't forget that it also includes a decent function generator.
Don't get me wrong, the 1014 isn't a Tektronix, but I submit that 100% of what we do as machinery hobbiests doesn't require a Tek.
The Rigol is a very nice scope but it isn't a Tek either. And it doesn't have a function generator. My opinion is that the 1014D is a very good choice.
I just came upon this it seems a place of vast information on Scopes.
Good thing you are using it not me, cuz there is no way I'm ever gunna watch that much youtube!
But I do like the outline.
The new oscilloscope showed up today and so far I'm impressed. I compared it to my Iwatsu SS-5706A and they both read very close.
The signal generator I used has a tough time with a square wave once over 2 MHZ. The iwatsu probably cost as much as a new car in the mid 1980's.
I got this 15A DC motor speed controller from Princess Auto today for $3. I was wondering if I could use it to control a DC motor on my South Bend lathe? The current motor is about 1HP and I would want about the same power. Is there a particular variant of DC motor I would need to use? The board has pins for external connections labelled L1, L2/P1,P2,P3/T1, T2/ and M+,M-. I'm guessing these are for a switch, a potentiometer, a motor, and power but not sure which is which(I'm guessing M+- is power, P1,P2,P3 is potentiometer). Any thoughts?
I'm going to guess L1, L2 are line 1 and 2 input. M+ and M- are the DC motor and P1..P3 are the potentiometer for speed control.
I second @jcdammeyer 's guesses.
L is almost always Line in.
M is almost always Motor.
P can be many things but a voltage dividing potentiometer makes the most sense since there are 3 connections and most pots have three connections.
The controller is similar to one I bought to run this 1.5HP 100VDC treadmill motor. The other end of the motor shaft is a bit bunged up so I'm not sure how well I could add an encoder to it to determine unloaded RPM but it does wind up pretty fast. Here's a quick 1 minute video I made.
What kind of resistive value did you use for a potentiometer?
It's marked 5K. I believe it came with the controller. The motor came from PA. I don't remember where I got the controller. Ebay or Amazon I think.
Edit: Apparently my controller is called an MC60 series motor controller. Prices range all over the place.
Lol. I bought a couple of them today as well and just sat down to ask the same questions.
T1 and T2 is a bit odd for an MC60 controller. These terminals might be for a thermal cutout switch inside the motor. If nothing happens when you wire up your pot/motor/line, check for line voltage across T1/T2.
Other thing to watch for is many of these have a zero-start function, so the pot has to be zero before the motor will start. Think treadmill - we don’t want Gramma to be launched across the room if the treadmill starts at 90mph.
Coincidentally I scooped up a free treadmill today (Weslo Cadence 860) with the MC-60 controller and the much sought after motor choke. For reference, the slider type pot on the console has a 10k value.
Before any vultures take flight and eye up the choke, it's earmarked for an SCR type controller combo. It's the main reason I picked up that TM.
I'm on a roll this week, that was my third freebie. Kijiji is my friend! :D
D :cool:
LOL! I eyed up one of these at PA yesterday and walked away thinking I didn't know enough about it to make it worth playing with. The had a whole box of them on the shelf.
I've come into a number of interesting boards from treadmills lately but with what's turned up in this thread it might be worth the $2.99 each to pick up one or two to play with.
D :cool:
The "T" connections may be for "tach" input. That leads to the question what are they doing with it?
D :cool:
