Brent H
@Canadium has it stripped right down. The big lads will probably take a dry lift and see if they can just carry it. I get out the pom poms for such feats of strength and offer encouragement. If it is too heavy for a safe "up and out" we will engine lift it off and move over to the stairs. Trailer will be pulled right up to the door and we can then winch it out up the stairs and onto the trailer. I will make up a stair sled and some rails so it should just carry on up. Base will be similar after a good cleaning.
Once on the scene we will get set and take a few pictures, alter those pictures in a suitable software to bulk us up and make it look easy
Some of the lathe is fibre glass (back cover) so we will need to be sure not to bang things around. I have a multitude of moving blankets, straps, chainfalls and come-alongs so we should be fairly set. The trailer is all steel tube and can tilt so that helps at the door.
Wrap it all up snug, drive across town for the off load, set it up as required and vanish into the afternoon.......
Sounds romantic
Sounds romantic
