Way to go on the move and the new lathe. How many lathes in basements have been covered up with new walls instead of moving them out?![]()
Right off the start I've run into a glitch with the reassembly of the lathe. I imagine the first of many glitches to follow! I need to repair the threads on the bolts that hold the bed to the base. I thought I already had all the taps and dies I would ever need. But low and behold these bolts have an uncommon 1/2 X 12 BSW thread. So now I'm waiting for my new BSW tap and die set to arrive.
@Canadium - 1/2 x 12 ? Dirty buggers.... that would be why there was no nuts on them at the beginning. Must have come down those stairs in two pieces at least and the nuts were lost in transit. Are you making new nuts?
Can you not replace the bolts with something standard or metric?
What is the approximate age of the machine? (Did I miss this earlier?) I thought it was a 1960's machine or thereabouts. Nothing that new would use BSW, right?
Post #65 shows the lathe is labelled as "Elliot-Willson". From http://www.lathes.co.uk/willson/index.html -
"The Company [Wilson] went public in 1947, with Albert Kitchen as chairman, and were absorbed into the large Elliot Machine Tool Group in 1966."
Seems likely to me that the machine was produced after the merger as it has the combined name. So late 1960's or after.
@YYCHM not even close I'm afraid. I'm too much of a fusspot. Since everything is already in pieces I'm doing a lot of cleaning and repainting and trying to spruce it up while I wait for a BSW tap and die set and a manual to come from England.
