@YYCHM - it was an epic event that I will say this: do not install industrial machinery in your basement unless you wish to just leave it when your done or you have a sick sense of humour. Yes, some cannot afford or wish a garage but I have to tell ya -
For the move I welded on a 1800 pound winch to the trailer you see in the pic. My one son ran that while my other boy and I lifted/pulled and cursed the pieces from the basement. Had it been my place I would have cut out the one wall - saving 2 hours - but alas not to happen.
We lifted the lathe from the base and removed 3 studs that were holding it in position. - lowered it with the travel crane. The base contained a 5 HP motor
- heavy as all get out- in bolted and took off some electrical. - will email you those pics
@Canadium. Owners still had the 2x4 crossing the door so you couldn’t just roll out the base - argh- rotated and flipped sideways out the door and set onto the stairs on a piece of plywood. C’mitchie cranked the winch and Greg and I slipped slided and rocked the base up the stairs. At the top
@Canadium got some support into the trailer and we slide the base home.
lathe was next and OH My ..... heavy and no lifting points to speak of. Casting is a combination of a slant base and the flat base. Built for accuracy and long life - head stock is massive.
we Porto craned it to the door of the furnace room and then swung the heavy end onto a trolly rolled it out as far as possible and then put the second trolly in. Greg and I dead lifted the trolly wheels over that cursed door sill and got the lathe lined up with the stairs.
hooked up the winch and Cmitchie started cranking. Dead lifted the headstock up the stairs to clear the casing cover and we were going up. About 3/4 ways we started to get the whole lathe bearing on the steps and the bottom casting part dug in - cursing and sweating like crazy ..... grabbed a 1-1/2 ton chain fall and
@Canadium and I ran my tow line under the trailer and we put a second line on the lathe. Chains flying, winch cranking, lathe moving. Put second board across the trailer to span from the house and some blocking under and cranked the lathe onto the trailer while Greg lifted the back end.
cleaned up and put doors back on, moved trailer back to the truck and headed for
@Canadium ’s place.
Project start -0800 - arrived at site 1000 hrs. Lathe out and in transit 1400 ish
@Canadium lives close so 40 minutes later we started the unload. Crazy back up and squeezed trailer into his drive. Combination of pallet jack and ports crane and we had the Lathe off and in the shelter in about 1 hour.
Pizza and a quick drink with some chat and we were on the way home. Rained 2 x on the route home but was fine for the move. Very epic indeed!
basement moves - not recommended
Pictures- well, we started to take them but my phone was in the truck - my boys- well, they were pretty busy,
@Canadium got the camera out and then had to assist with the chain falls - we needed a photo person but my third lad slept in - LOL.
The lathe is a real beast - beautiful piece of machinery. Once all cleaned up and set to work it should be a joy to use. The parts
@Canadium removed are built - they are beefy and definitely this lathe is a production shop go to.
great to meet you
@Canadium - so funny the tar and the brush so to speak. I will check on the gears and see if I can make you a set. Thanks for the hospitality- perfect set up you have for such things in the covid times.
