Sticky What Machines Do You have?
Wow, I just realized today that I had not shared in this thread like everyone else has, even after years of lurking here, lol. So to be fair, thus far this is what is in my (currently unfinished new) shop, in various states of repair:
Functional (once drywall and wiring in):
- First LC-1-1/2 TS mill
- King Canada KC-1236ML 12"x36" lathe
- Alba 1A 10" shaper (about wartime era)
- King Canada KC-129C 4-1/2"x6" Bandsaw
- Lincoln TIG200 welder
- Ryobi 10" bench top drill press
- More bench grinders than you can shake a stick at
Project Machines (in various states of repair)
-Westward (Taiwanese) RDM270F 20-1/2" drill press
- Speeder (Taiwanese) 7"x12" bandsaw
There are still some machines that I would like to either obtain or build (such as a belt grinder) but will need time and funds to get there, such is the story for most of us. I will never call my shop "done," even after insulation is in, drywall and wiring are done, machines are in place, and tools sorted into cabinets again. That's because as soon as it's "done" then something comes along to need rearranging everything again (new machine, moving, etc.), lol!
We used Rockwool for insulation and 1/4 “ ply on the walls as well as led lighting that makes a big difference we also put in a full size electrical panel because you can’t have enough 120/240 plugs.
Busy Bee CT129 mill
Busy Bee B2227 lathe
King bench drill press
Milwaukee 6232 bandsaw on SWAG stand
Roper-Whitney #12 punch (favourite bench tool)
dozens of drills, angle grinders, saws
I guess i never listed my stuff either.
15x48 Colchester lathe
Who Flung Dung RF 30 mill drill
3 ton arbor press
Home built hydraulic press
Miller Mig welder
Acklands AC/DC portable welder
Band saw, oxy/propane torch and thousands of shop tools
My turn.
3HP Compressor that replaced 40 year old Sears 2HP that finally died plus lots of air tools and spray guns.
House of Tools Mill equivalent to Grizzly G3616 (with LinuxCNC) and Shumatech DRO-350
1942 South Bend Heavy 10L lathe with ELS and only Z powered.
Homebuilt Gingery Lathe with ELS both Z and X powered.
7x10" Metal Bandsaw on tall cart.
3 Ton Arbor Press, Ring Roller, Bead Roller, 30" Sheet metal 3:1 Roller, Bender Shear, Corner Notcher.
Natural Gas fired Gingery Size Foundry with Electronic Ignition and automatic FAN speed control
Oxy/Acet tanks and welding/cutting tools
MIG Welder
Homemade JGRO style CNC Router with MACH3.
Cheapy Far East 3D printer
And in the wood shop
1997 Delta 10" table saw
1934 Delta 14" Bandsaw
9"+4" combo Disk/Belt Sander
6" Jointer
16" Surface Planer
Home made Wood Lathe
Sears 16" Drill Press with hollow spindle for draw-bar to hold onto MT3 tooling plus XY Table and XY Vise.
Small Sears Router Table
And of course lots of little tools and bits and pieces.
Oh and finally a few square feet of walking/standing room... very few square feet...
My turn
Logan 825-1 lathe [sold Dec 13 1945 per Scott Logan in US], purchased in Bowser, V.I. in 2015 or so
Atlas 10D 1930's [current rebuild project] used at the Jericho DND facility during WW11 and ended up on Thetis Island in the '50's
1992 Delta 12"disk 6"belt sander restored, SD68 broken unit bought at auction for $50 in 2018
1940's Delta 1460 wood lathe c/w 1930's Robbins & Meyers 2HP 3ph motor & VFD
14" Delta 995 triple duty drill press from the mid 1930's
GI mortising machine, drill press, 17" Bandsaw
General 10" tables
Delta 6" jointer
2021 Xmas present from son & family No 311 Wells Bros Galt Ontario vintage tap & die set
My turn
General 10" tables
Delta 6" jointer
Don't you just love the old iron. My Delta Band saw was procured from the Cub/Scout camp at Bragg Creek west of Calgary when I was 17 years old. It was rusted and slated for the burn pit. I rescued it and cleaned it up and painted it. My father used it as part of an Osprey-II home built aircraft which unfortunately was never finished. I have it here now in Victoria and I hope it will stay in my family forever.
1960s Ta Shin 10 x 24 lathe (with gear box) (soon to be for sale)
1970 Myford ML7 (bought this week :) )
??? Adept (standard, not complete) (soon to be for sale)
??? Wolf Jahn WW watchmaker lathe
??? Star Geneva-pattern watchmaker lathe (soon to be for sale)
1948 Rhodes 7" shaper (unfortunately not the model with the rotating box)
2000 Force (House of Tools brand) RF25 mill (maybe for sale if I get the crate from the UK :) )
Import h/v band saw
10" power hack saw for the nasty jobs (I think it is a combo-machine, frame make does not match the base make as far as I can tell, but it works well if not slow).
bench sander or two
bench grinder (6", mounted on an old drill press table using the platform for grinding guides of various sorts)
Dave
Import h/v band saw
bench sander or two
Dave
Did you buy the ML7 from Moose Jaw?
I saw it is listed as sold today.
Craftex CT043 12 X 36 Lathe
Craftex B048 8 x 30 Knee Mill
Hoo Flung Poo 25 mm mill / drill
Craftsman 10" benchtop drill press
Sioux 2001 valve grinder
Sioux seat grinder kit
Sunnen LBB1699K Hone machine
Van Norman 944 Boring bar
Craftex & Craftsman bench grinders
4 1/2" x 6" band saw - horizontal / verticle
20 ton hydraulic press
3 ton arbor press
Millermatic 175 mig welder
Miller Syncrowave 180 SD - Tig / Stick welder
Husky air compressor
Power fist - bead blast cabinet ( hot rodded )
A bunch of wood butchering equipment
& a pile of other stuff
Modern 14”x40” lathe
Modern 22”x80” Lathe
Modern drill grinder 1/4”-3” capacity
Modern 10”x 50” milling machine
50 ton press
Jet geared drill press
7”x12” metal band saw
Bend Pak 10 000lb 2 post vehicle lift
Danmar 7000lb 4 post vehicle lift
3 ton overhead crane
77’x 80’ shop
Bet you I have you beat on that one:p
I might win for the most stuff in the smallest space.
There is a problem here:
Most stuff in the smallest space could be:
Stuff/ft3
Stuff/ft3 min
Stuff max/ft3
Or stuff max / ft3 min
I think you guys are stacking the deck through ambiguity.
Not sure why you would even want to win under any of those measures though......
But hey, I'll play too..... Not gunna bother entering under either ft3 min categories though. Do farm tractors count as stuff? ;)
Two moves ago I had my lathe/mill combo machine and all my tooling in a lean-to garden shed 6’ w x 6’ l x 6’ h, tapering to 5ft high at the lower end of the roof. Walls were covered floor to ceiling with bin boxes on 6” deep shelves.
I suspect that you win by all 4 measures......
