I appreciate your comments. This design concept is far from complete, lots of bugs to work out. Yet I'm glad you don't see any show-stoppers. The two main focuses were to: make it a bit more compact; and to incorporate an easy-to-change pair of step pulleys. I'd likely use 4 steps on the pulleys (not 3 steps as in my sketch). A bigger motor with a VFD would be a huge improvement but also a HUGE cost increase.
I agree that the motor I have is a bit on the small side and more is usually better in this kind of a project. If I decide to proceed, the motor may get upgraded first.
But - it is an old-school 7.8 amp 1/2 Hp Baldor and weighs-in at 34 pounds. In comparison, my Crappy Tire 8" bench grinder claims to give 1/2 Hp from 5 amps and it weighs 32 pounds (that's complete with grinding wheels and a work light).
@CWret - my 4x36 belt sander has a half horse motor on it. It's 4.3 amps on 115 only - no 220 option. It's more than enough. I tried to stall it. Not happening without jumping or destroying the belt.
I'm not saying that more horsepower wouldn't be better. Just that 1/2 seems to work just fine for what I do with it. The platten on it is 5x12.
Kinda like a skidoo/ATV transmission??
Thanks but - No idea how that would/could be made to work.
You could use or make a variable pulley View attachment 57695
Funny you mention that. At one point I was seriously considering making a mechanical variable speed system like Paul Brodie has on his drill press in the video below.
I also had an idea to hide the motor/drive under the table, and run the drive wheel via bevel gear, so that I could still swivel around the gear center.
Lots of mental masturbation for years about cool and different ways to build one, but I'm at the point where now, I just want it to help me make other things. Over complicating things, just ensures they never actually get done.
Lots of old relic combines still sitting around farm yards in the west that would still have a functioning Cylinder and fan drives that are variable speed shiv's similar to this drive. it might take a few hours to source on but surely do'able.
Cleaned out my tools from the car this morning, and couldn't help but laugh about the size difference of hardware I used to work with, compared to what I work with now..... A #4-40x0.375" flat head vs a 1.25"-12x9" (torched shorter) Flat head.
Saved a few from the scrap bin so I can turn the axles for the grinder from them.
Ha it is funny how there is such a variety in the same trade for some trades, and everyone has an idea what that trade is
Millwrighting is one of the tougher ones to explain that's for sure
Belt grinder side quest #2......
I've been thinking round and round in circles the past few days about how to make my drive wheel, while chipping away at the other components. The leading method was to roll one from flat, similar to how I made my other steel wheels, but with a machined hub/keyway. I wasn't really opposed to that, I think it's a pretty viable option, but for some reason I couldn't figure out why I wasn't 100% on it.....Then it hit me. I didn't need anything to do that. I have everything here, I have the tools, the material, the method figured out, I could crank one out in an afternoon, and it's the easiet path to victory. But where's the fun in that? The majority of time, I choose my projects and methods for specific reasons. I'm always trying to expand the capabilites of the shop and to further my own knowledge and experience learning new things. It's not always about making "the thing". It's also about the journey to get there.
Back at the start of this, I'd given a quick thought to casting one. Not a bad idea, but how? My little electric foundry is too small. I've always wanted to build a bigger one, and have had a collection of parts lying around acclimatizing for years, but it's a tall task to get up and running and too big of a side quest to just to do one wheel.....What about the coal forge? Or the ribbon burner forge? I'd have to make a steel crucible, but either would work to heat up a suitably sized crucible to cast the wheel. Great, now about molding. My homemade greensand sucks, I don't want to buy any right now either. I'd also have to build a new flask, make a pattern etc.....Lost PLA? I don't have a kiln to burn it out, but lost foam? Hmmmm. Always wanted to try it, but haven't had the right project to give it a go. The wheel seems like as good a project as any. But how do I cut the foam pattern......CNC?, lathe? Too easy. Hot wire would work great, but I don't have one....Perfect.
Started mulling over a design the past couple days. Wanted it it to be a quick and simple build and was simply going to hack together something out of plywood but once I got going on it, I start gravitating in a diferent direction....one thing led to another and now I have a hot wire cutter....
I didn't really take a lot of pics along the way, and this was very much a build from the junkpile with minimal effort type of build.
This is the frame underneath. I tried to make it stout, but adjustable in every which way. The wire is clamped to the lower frame with a homemade clamp, it runs through a steel tube (inflator needle) pressed into the table, and then through the same, but curved 90* in the upper arm. A simple loop hooked on a spring completes the connection. The table is adjustable so I can line up the lower bushing with the upper one for square cuts. The arm is adjustable in/out so I can cut a taper if I want to.
I'm pretty happy with it. Still need to make a fence, and adjustable pivot for cutting circles, but that shouldn't be too bad. Right now I'm using 0.02" stainless lock wire, but have a few other types of old guitar string to try out too. Using an adjustable bench power supply to power it.
And a shot of the bench while I was building this, just to appease the resident squatch. This is pretty normal around here. A project on top of a project, on top of a project.....
Well, at least I got one project finished on the bench today.....
About 90% of the time, that's how ALL my benches look. I can't be trusted with flat surfaces. When I'm done with a project however, I love nothing more than cleaning up, and putting all my tools back into their homes. The problem is I always have multiple projects going on, so that's a rarity, but it does actually happen once in a while......
FINALLY.....It's here
Ordered mid December. Was really hoping it would have came around/before Christmas so I could have used that time off to clean out my sump, and get the Tormach up and running again finally. Amazon and other retailers shipping/processing times have spoiled me I guess. Oh well, it's here, and I now I have a fun job to look forward to after dinner tonight.....I don't know what's worse, replating a garbage boiler feed chute, or cleaning a coolant sump......If I don't make it back, it's because I contracted some sort of super bacterial disease from the flubber growing in my sump. Enjoy the farm auction.....
If I don't die, I'll be back on the grinder project milling out parts tomorrow......Can't wait to mix it up actually. I don't think I've ever been this excited to mix coolant before, but from all accounts this stuff sounds like unicorn piss it's that good. Certainly priced like it.
