Sus and his horizontal surfaces 🙄
It’s just his way to “organize” his tools.
The mill will be inside an enclosure so the potential for this to be tool storage is minimized 😀I tried to camouflage the real purpose for @DavidR8 but you guys saw right through me!
Nothing beats a horizontal surface for keeping things visible and ready to go!
Now to mark the holes to secure the ball screw mount.
And done.
I actually thought that took ages.How the Fk did you manage to knock that all off in such a short time!
It's embarrassing you know.
Don't you have another shop to build or something?
I haven’t powder coated it yet so it’s not done, done.
In the future it will be a cup 'o chips! 😀At least put a cup holder on it!
Agreed. I’ll probably TIG some sides onto it before I finish it up.I like the idea of the shelf, but I think using plate to implement it might not be the best answer. If you plan on sticking with the plate it would be wise to add a front and back side plate to it.
You will see some flex the way it is set up now and that might load up your ballscrew nut as the ball screw flexs out of alignment.
At our age we are all getting a little low in iron anyway..... 🙄In the future it will be a cup 'o chips! 😀
I see some of my luck might be rubbing off on you....... It's a tough path ahead. 🙄The new timing belt pulley for the servo motor arrived today. Motor spec sheets said 19.6mm shaft so I went looking for pulleys with 20mm bore.
Pulley bore is spot on, 20.1mm. Offer it up to the spindle and it's loose like a baggy sweater... mic the shaft and it's 18.89mm, almost 1mm smaller in diameter.
Unfortunately not. No big deal. At $10 the pulley was cheap enough to put in stock and chalk it up to learning.Is there enough meat to bore it past the keyway and then sleeve and rebore it?
What I take from that photo is @DavidR8 is trying to slip your mill into his back pocket (to take home) but you caught him with a photo so now he's pretending to measure something.A productive morning, and a happy @DavidR8 . He can moderate the picture (and this sentence?) out of existence if he doesn't like it ;-)
