That would have a lot to do with the thickness of the material as far as tooth engagement
Try a 10/14tpi combo Lennox blade next time you're due for a change. I get them from kmstools, if you don't have one in your city they ship and I think it's free over $100, sometimes $50, or used to be.I have always used 14 tpi on my 4x6 bandsaw because that's what it came with and thats what Princes Auto sells. Have others used different tpi blades on these saw? Is there a better tpi for all round general hobby use for a saw this size?
I also predominantly use variable tooth blades (10/14 I believe) but have single 8 pitch coarse blade for bigger/faster stuff. I don't cut any real thin wall stuff with band saw buy go to abrasive chop saw for that usually.I have always used 14 tpi on my 4x6 bandsaw because that's what it came with and thats what Princes Auto sells. Have others used different tpi blades on these saw? Is there a better tpi for all round general hobby use for a saw this size?
Thanks I just put a new blade on but will order one if the shipping is reasonable.Try a 10/14tpi combo Lennox blade next time you're due for a change. I get them from kmstools, if you don't have one in your city they ship and I think it's free over $100, sometimes $50, or used to be.
Lenox 64.5" x 1/2" 10/14 TPI Bi-Metal Band Saw Blade
With M-42 high speed steel tooth tips and flexible alloy steel backing, Lenox Diemaster 2 metal-cutting band saw blades deliver cutting performance and durability—lasting up to 10 times longer than carbon blades. Diemaster 2 blades are ideal for most genewww.kmstools.com
Actually a damn good sale price right now
Amazon pricing is funny. Sometimes they are significantly cheaper and sometimes they are 2x the price due to their pricing algorithm. Pays to look around before ya order.I only use one pitch (10/14) and one blade for all materials on my 4x6. When cutting wide material I reduce the downfeed pressure (hydraulic upgrade) to avoid overloading the gullets and tearing out teeth. I've been getting excellent life from the iMachinist blades off Amazon. I do believe that Lenox are the cream, but I doubt I would ever see enough difference to justify the price difference. (I just looked at the price on Amazon.ca for those blades, YIKES!)
The issue of carbon steel contamination of stainless is an interesting one. Are we to only use stainless steel saw blades and endmills? 😉
Back to the OT, I recently acquired a Tapmatic 50X tapping head and have been kicking myself to not doing so much sooner.
It's not contamination from the hard cutting tool edges, it's from carbon steel particles that may be adhering to the cutting tools.I only use one pitch (10/14) and one blade for all materials on my 4x6. When cutting wide material I reduce the downfeed pressure (hydraulic upgrade) to avoid overloading the gullets and tearing out teeth. I've been getting excellent life from the iMachinist blades off Amazon. I do believe that Lenox are the cream, but I doubt I would ever see enough difference to justify the price difference. (I just looked at the price on Amazon.ca for those blades, YIKES!)
Sorry the Chinese Company that I bought the. Saw blades from was . . .I bought a couple saw blades from FOXBORO in China (June 2022).
(2) 44-78” x 1/2” 24tpi bi-metal blades
I am still using the ‘first’ blade to cut Aluminum, MS 1018 HRS.
Of course, I would call my use of the saw - weekly at most.
I do not recall the actual pricing, but, it was less then NA suppliers.
Good point. Can't use low tpi on anything thin. Maybe @SkookumRob can help demystify all this.
Ditto. Never would have crossed my mind to order blades from Skookum till I saw his post.
Question for the man....
@SkookumRob - what do you think about mixing materials steel, aluminium, stainless, copper & it's alloys on the same blade? Also, if there is such a thing as one blade for everything, what is it?
It’s been awhile since I saw someone’s post about a magnetic swarf pickup tool.
My beard and chest hair seems to be a real good magnet for that stuff.Don't know how I lived without it. Wish they had one for Aluminium and for Brass......
Grab the rat’s nests with a long pair of tweezers, then vacuum up the little bits.For many many years, I used a small magnet on a long extending handle. Then I got one like yours.
