Sourcing Metal | General Discussion
Hi Tom. I don't have any experience turning 4130, but just wondering if you have 1.5-2" dia?
"Up to 10" round"... those must be some hefty paperweights you acquired! I kind of had my heart set on using cast iron to make some tooling & plates for my rotary table. CI round slabs are cheap in the states but that doesn't do me any good until shipped here. Could something like 6" dia be slabbed off into ~3/4" thickness, or is that what you mean by needing a new saw? I've had so-so experience machining bigger plates from cold drawn, sometimes they like to unload & warp a bit, mind you that was bar, not round.
There are some smaller stuff coming in tomorrow and I may have some 2''. I have to see whatever my little saw can manage a 6''. I have lots of the 6.25 inch stuff. I let you know tomorrow. I only turned it once. It leaves a nice shiny finish. In a chuck I didn't damage the surface when I chucked it in - definitely step up in hardness from "scrap". Didn't have issues drilling with quality drill bit. Cheap Chinese inserts died quickly. Premium US inserts seem to last through - I cut off few pounds on a single edge and its still good.
10"! Pizzas! Logs! You'll need a crane. We need a photo...
10" bar stock, 340 pounds per linear foot.
Well, the 9.5 inch 4 ft log is nice. Its not that heavy once you get it to roll. No idea how am I going to get it onto a saw to cut a slice. First is getting at least 9 x 16 saw to actually have something to cut this thing with.
Right now there are many logs in a pile in my back yard. I simply got angry about not having ability to get any steel and got a bit overboard with what I got.
I also got small piece of aluminium and stainless.
I work on a list over the weekend. I have few small 3'' pieces, more 4'' pieces of say 10 inch length and then even more 5''. Most I have is of 6.25'' pieces. I also have some pipe as well as stainless. Just one large piece of aluminium.
I take one on the weekend - I am usually home after dark. Dabbler can also take on when he comes by with a bucket of cash to remove some of it.
Just got home from Tom's. He has quite a pile of round stock sitting there. All of it is 4" or larger in diameter, some of it heavy wall tubing. I picked up a few shorter 4" pieces for future use (I don't have a need for it at the moment). I met his dad, too we must have talked about machining and stuff for an hour. Thanks again, Tom!
Was just over at Steel Inc to get some Square tubing to liberate my mill from 'pallet madness'. He as usual filled the order very quickly, enthusiastically and economically.
He wanted me to pass on a big thanks for the positive reviews and the business he has had from our group.
I know someone wanted some cast iron pieces but I am not sure who. I have two, both over 1ft long. One is 4.5 inch round the other is 5.5 inch round. Let me know if you are interested.
I PM'd you about cast iron. I can take the longer of the 2, or a short piece if someone else needs the long one. I was also interested in a piece of the thing that had a 2" hole in the center, 4140, about 8" in diameter, I think. I can come over again and look if you'd like
I picked up several pounds of yellow brass strips at auction. They are about 7/8" wide, up to 1/8" thick and up to 24" long.
I have more than I need so am willing to sell the rest at $2/lb.
Well, their problem - federal was always cheaper anyways. Besides I seem to have plenty of steel stored for milling and welding its federal.
Wait till steel inc goes under and buy at 10% of the price.
