@Kelly McLaughlin - the marks on that piece were not from me, it was an end cut in the scrap bin - yes, in the bin......
@Dabbler : I believe I have somewhat dodged a bullet and will be able to at least carry on with some other work - I took the assembly apart this morning. I was going to pull this part of the lathe apart eventually (again) to remake the fine/course selector shaft as it is somewhat disgusting and remake that bronze gear as my repair was just that- repaired but not permanent. I found something in my repair that must have been part of the failing process.
@Marc Moreau and any other Utilathe owners may be interesting in the following so bear with me as there are a bunch of pictures.
Removing the main shaft assembly starts with taking off the chuck and the top lid on the lathe. The main shaft is held in place by the friction fit of the bearings and the collar on the back of the shaft. This collar is used to pre-load the conical Timkin bearing at the front of the lathe. It screws onto the drive shaft and is locked with a set screw - this set screw has a piece of brass under it to prevent the threads of the shaft from being marred - be careful not to loose it!
loosen off the set screw and undo the collar. I put the lathe in the lowest speed to help lock it up and then using an appropriately sized punch or rod, turn off the collar. Mine came off easily as it is just loading the front conical bearing and should not be jammed up tight. If it is all jammed up tight it will take a few taps of a dead blow hammer on the turning rod to get it moving.
Once the collar is off, you can drive out the main shaft. It will move fairly easily with some solid dead blow hammer blows to the back of the shaft. Support the front of the spindle as you drive it out.
the front of the shaft will unseat from the conical bearing, once free you can then stop hammering and simply pull out the shaft by wiggling and making sure not to jam up the two gears on the shaft. They should slip off as the shaft is pulled out.
You can lift out the smaller gear. To get the slow speed gear out you need to pull out the speed selector shaft - I will not be showing that as my issue is with the gear cluster on the lower left of the picture.
There is a set screw that locks a collar on the fine/course selector plunger. Loosen it and remove the collar. The fine/course selector shaft can now be pulled out with the drive gear attached. The drive gear is pinned to the shaft by a brass 1/8" diameter shear pin. Held in place with a cir clip. If this is not brass - replace it with brass - I use a 1/8" brazing rod with the flux removed - works well
Note how crappy that shaft looks!!
😵 - this is why I was going to make a new one - it does have one difficult part - that round spring loaded key.....As the selector is pulled or pushed from fine - to course feed, that key is compressed into the shaft and then springs up into a key way in the gear that either drives the feed faster or slower. The gear I am after is a bronze one that drives the courser feeds from 4 to somewhere around 24 TPI. Having this shaft out now is good as I will make a measured drawing a reproduce it as far as possible on the lathe and then it will needsome milling for that key - there will be a bit of a fix to the way the key is fitted to make the shaft smoother in that area. Originally a hole was drilled right through for the spring and then a piece of brass strip was hammered in to retain the spring - I think I can mill a pocket for the spring, add a small bleed hole for lubrication and that will keep the shaft smoother.....anyway...
After this shaft is out you can reach under the large slow feed (60 Tooth) gear and pop it out with the spacer and washer. Then you can pull out the 25 tooth bronze gear that is causing me the issue -
You then have a pile of stuff on the work bench:
So - You will see that my gear did not "fail" in the sense that it is still looking quite intact. There is, however, an issue on the inside where I made my repair. I cut the key way in with an end mill and left it round and did not file the sides to square it up as I did not want to remove all the repair material. I had to bore this on the mill (see start of this thread). the rounded side was not enough to keep the spring key from collapsing under the load of 8 TPI cutting.
So, ugh, I do not have any material to make a new one at this time and I am back to the ships on Wednesday. I am taking lots of measurements. This gear is a 25 Tooth 16 DP 14.5 PA - I have those cutters. The larger slow speed gear is a 60 tooth 18 DP gear - don't have those cutters -yet......So, I will take notes on everything and then re-assemble things backwards steps. I filed the sides of the key way flatter and will insert the gear 180 so that the loading is on the face that was not tore up. I think what I will do is make a wide blank (like 3 gears wide) and then cut the teeth into it, properly key cut it , and then part off 3 gears for future. The gear is only 1/2" wide so it is not a lot of material.
I will stay away from threading at the lower feeds Until I can get this fixed 100% - as I am back to work Wednesday I can leave things and make up the blanks at work and then cut the gears when I get home in a month.....argh......
