Brent H
Well this tapered gib for the compound was quite the project. Cast iron is a hard material. When you have a cutter that is a bit out of round - well it is harder to cut. Couple that with a sudden horrible back gear sound and things can get exciting! So after finding out my 30° end mill was out 0.0015” but being without options I slowed my feed and shifted to a slower mill speed. Then came the grinding sound that was not the bit cutting a hair out of round - it was the Bridgeport back gears growling away.
With everything set up and measurements on the money I proceeded to tear the head off the mill to access the back gears and see what was amiss. I found that the gears were not engaging fully with the main drive gear and also there was a need for more grease. After packing a half tube of grease Into the head I had one of my boys hold the main gear in position and set the lever up on the side. Then reassembled and started milling again in a much quieter environment.
I milled the blank to thickness and then used a 60° cutter setup (sort of a hodgepodge or cutter and holder) to cut the angle on the straight side of the gib.
once that side was done I set up with my jig for cutting the taper and just about screwed the whole thing up! I set the compound up and used it to turn my vice to the angle required for the gib. I used a test indicator to dial it in to 0.0000”. Total excitement and then it dawned on me that it would cut my angle opposite to what I needed - crap, what to do......my vice has the swivel base still on it so I set a dial indicator up at zero on one edge of the vice. I then moved the table over to the other side of the vice and swivelled the vice until my indicator came back to zero - sweet! I did a few other checks and things looked good!
roughed in the angle with a roughing mill and then cut the 30° bevel with my out of round cutter.
After milling I had several hours of scrapping and lapping and some grinding
Yep- the front of my compound is some chowdered up still, even after welding repairs - BUT!!!!!! The dang thing runs butter smooth now without end play !!! Yeh me!!! And my mill back gears are all set properly as well !!
