So a few weeks ago I purchased a 10' LD Standard Modern Utilathe serial number U530. The serial number is a bit like a submarine so I hope this project stays afloat and the lathe doesn't become a dive site somewhere. I have not had much time to do anything with it, basically get it home to the shop and leave for work and so far I have been vicariously making plans and some parts by texting my son and getting him to send me pictures.
Research through all the Standard Modern sites and you tube videos has proven to be somewhat beneficial, however, the 10" Utilathe seems to be somewhat lacking of any accurate detailed description. I have the manual for the 12 x 30 and it has reference to the 10 x 20 - some specifics in the parts section and a few measurements.
If all goes as per plan, I hope to create my own manual for the unit with accurate description and proper parts - with sources. So far I have been able to track down the Gits Oil cups and have those ordered and on the way and I have gone through the bearings (according to the manual) and have been able to find the Oilite bushings, needle bearings, and the SKF roller bearings.
If anyone out there has worked on this particular model, perhaps they can let me know if the bearing list in the manual is accurate - is the Timkin 18720&18790 the "as fitted" bearing/race or is it different - the 12 x 30 is listed with a threaded spindle where as the 10" I have has a D1-3 . Also there is a bearing fitted to the change gearbox upper shaft listed as a 6202-ZZ but this is crossed out and someone penciled in 3204....hmmmm
I am also converting (very slowly) some of the drawings of the 1120 1324 models into autocad so I can possibly machine a few of the parts that are the same. Bigger projects will include making a taper attachment, steady rest and other items
So far I have made up a new cast Iron 2 step drive pulley for the unit and will getting the original 1 hp, 220 volt 3 phase motor cleaned up and ready for action.
I am planning to use a VFD to convert the shop power for 3 phase. I have one on my mill and it works great. The VFD is a 3 Hp rated one so I should also be able to program the ramping to allow for some dynamic breaking when stopping the motor.
There is some minor damage at the face of the compound - will try a repair there and I will be making a new cast iron gib for the cross feed (brass one fitted right now).
If anyone has any advice/knowledge/documentation/parts It would be great!
Here is a couple pictures as set into the shop - nothing done at all
View attachment 5340View attachment 5341
