Is that the original stand for the shaper? I cant imagine it would be, but I have heard weirder things too lol. If it is I would be leary of cutting it down, I am weird like that and like to keep stuff original! If its not cut cut cut lol.
Yes, 4” swivelling castor wheels, rated for 250# each, mounted onto 2x6s. Total height gain was 6.625”.
Here is a picture of how I had the casters mounted to 2x6s and they in turn were mounted to the cabinet via the aluminum angle brackets.
Besides the need for mobility, the 2x6s gave me the chance to widen the stance of the cabinet to reduce the sideways tipping-over possibility.
@kevin.decelles Could you please post some images of the bench you got with your Southbend shaper?
@CalgaryPT may be willing to take on a project on for me.
Thanks,
I'm thinking this is not the project to skimp on. Jury rigging the wood cabinet could be iffy and I'm convinced now my tool stand isn't up to the task.
A bench failure would be a real PITA...
Yes, it is. That’s my stand on the sidewalk when I brought home the machine. 🙂found a picture of what appears to be a stand for your machine.
I was wondering if it was yours. How is it working out for you?Yes, it is. That’s my stand on the sidewalk when I brought home the machine. 🙂
YYC - did you get to HD and have a look at the cabinet?
Ya, wasn't all that impressed. Seemed a little wobbly but that may have been the floor? That wobble will probably diminish significantly once you punk a 200+ lb machine on it. They had a $600 version there and you could really tell the difference. Mind you it weighted 3 times as much empty.
Don't know what to do now. Have something fabricated perhaps?
It’s working well. When I first got it (2014 ish) I had no milling capabilities so it was my go-to machine for lots of things. I have since acquired a small miller and they are usually quicker for generic operations so the shaper doesn’t get used as much anymore. But, I still turn to it for large area surfacing and stuff like that. It’s also really nice for indexing operations like dial graduations, etc. Cutters are cheap too, and they last a long time.I was wondering if it was yours. How is it working out for you?
I made a new base frame with 1.5 x 3 tubing and that made a big difference. I drilled and tapped new holes to mount the wheels and the tubing also let me mount leveling feet.
