Hi All,
Pushing on with adding centres to the 3.5" diameter bending head bar billet.
It seems simple enough but I was dreading this operation as I had never handled such a heavy piece in the big SB lathe before nor had I used the fixed steady before.
See the setup used, photos 7,8. I used a dial indicator to centre the far end of the bar in the fixed steady and a 3 jaw chuck at the headstock end but no matter what I tried, the fixed steady rest end of the bar would not centre better than to 0.007" runout. I measured the OD of the bar and it was good to 0.002" wherever I measured it.
To make matters worse, the bar wanted to walk out of the 3 jaw chuck when facing the end and I nearly had a disaster several times just stopping it in time each time.
What was going on?!!
Either my 3 jaw chuck was no good or the bar had been centreless ground and was lobed. I don't know but I will investigate. It obviously was misaligned somehow/somewhere. If you have any suggestions on what was happening or how to set it up better, please chip in.
Anyway, In the end, I did back off the steady rest fingers slightly until the bar turned freely in the steady rest. Then I very carefully faced each end of the bar and used several increasing sizes of centre drill to put a centre in each end of the bar. It was tense, intense, tense work.
I don't ever want to do this again.
to be continued.
