I just added a little busbar in my box that I can use to share the common with other devices.
That is odd. Most of the EStop buttons I've seen include both NO and NC connections. But it is what it is. You will either have to get a new NO Switch or use a relay to create a NO connection from the NC switch.
A few things to be aware of:
1. The VFD rapid stop function is often latching. Once engaged, it stays engaged until reset. You may need to cycle the power to exit the rapid function.
2. Rapid stop is not meant to be the normal start/stop function. The stop can be too aggressive for normal stops. Some systems even use a braking resistor to shorten brake times.
morning,
I did read up on it and asked E Motors, I was all set to put a braking resistor on it but the function is not supported, too bad because they're all over amazon some are quite reasonable in cost. I went to look for the NO block in the shop thinking I took it off but NO such luck. Back to amazon I go, 34$ for a pack of 4 NO/NC e stop buttons, a 110/240 tach and a 7/8 steel pulley; by Tuesday you all should have new pics.
Here is an idea for someone in the know here, find a vfd that supports stuff like mills and lathes and the so on with features like braking resistors to add on. I am far from the technical side of things but it would be a real help to find something designed for plug and play, fans, lights and other goodies to plug into a vfd, oh and cheap enough a fella or yes even a gal has beer money left over.
(off topic sort of)
I went into KMS in Nanaimo yesterday and they had quite a few motors on the shelf and when I asked two guys for a pulley the stared at me for a second tried to process the question and said you want a puller, they walked away to look and never came back to me.
😉 Another guy stopped me on the way out and asked if he could help, big mistake...
😉 I said every motor in here and you sell motors too there is not one pulley to be found, he said yah and we sell tools that we have no blades or cutters for too, we both laughed, criticized the world, swore a bit and went our own ways.
I really don't know how these businesses stay above water, KMS is a prime example, I go in there time to time, look at stuff, then go right to amazon and search, they must have decent house cleaning because the same items haven't moved spots in a year and no dust on them...
I'm all worn out now I need a nap
