I have the Busy Bee version of that machine.The closest reference is the Grizzly G103, looks identical. I just want to make sure I'm not missing something when using the power feed, I disengaged the threading gears and ran a test and no feed when I first got her home so logic would say the threading gears need to be engaged.
I am trying to weed out a coincidence, smoked the motor at top speed because it was ready to fail or did I put too much strain into the motor with a slow feed rate and high speed, I am leaning towards a tired motor.
Correct, I am not using the lead screw for making cuts, however I did engage the threading gears to slow the travel speed down on the saddle, the power feed reacts to the threading gear box, just need to make sure this is the correct way to do this, I don't see any other way to have a faster spindle speed and slow cut rates.I have the Busy Bee version of that machine.
The smaller lever under the power buttons controls the power to either the lead screw or the power feed drive.
Lever to the left = power feed drive engaged
Lever to the right = lead screw engaged
Middle = neither power feed or lead screw are engaged.
When using the power feed, the half nuts must not be engaged.
By threading gears I assume you mean the quick change gear box. And yes that is how you control the feed rate or the thread pitch independently of the spindle speed.Correct, I am not using the lead screw for making cuts, however I did engage the threading gears to slow the travel speed down on the saddle, the power feed reacts to the threading gear box, just need to make sure this is the correct way to do this, I don't see any other way to have a faster spindle speed and slow cut rates.
cheers..
yes correct,By threading gears I assume you mean the quick change gear box. And yes that is how you control the feed rate or the thread pitch independently of the spindle speed.
It's a safe bet that he had those parts because of some less than well informed use. 🙂yes correct,
So my hunch is the motor was well on the way out then, well past due. So when I bought the lathe from an experienced machinist it came with a few spare parts, one being a broken back gear assembly, spare new spindle and some other parts. All these clues tell me maybe even he got a few things wrong in the operation of this lathe and had to replace a few things due to incorrect operation.
My biggest concern is that I was putting too much strain on the motor and the gears were the cause of the motor cooking off; the problem arose when I woke up in the middle of the night and thought "what about this."
I'm thinking so, something I'm trying to avoid........😉It's a safe bet that he had those parts because of some less than well informed use. 🙂
NOT IMPRESSED to say the least, I just spent close to 1K on the vfd and the motor, then I find out the motor is vfd rated but doesn't have the proper shaft grounding to stop the bearings from degrading and arching and pitting the shaft/bearing races.
I sent them an email yesterday, yes they have been really good to speak to and Ashish was awesome to email technical talk. Purolater was the shipper, the motor was delayed because of vehicle issues, did they drive into a lake hence the water on the motor but it was a box in a box?Call then and they will make it right
I completely expected better quality in the in the wiring box, for a few dollars in parts and then seeing it on the box diagram it really ticked me off, after the damaged motor and finding water pooling on the motor it was like throwing more sand in my "gonch."Most likely shipping damage. No matter, E-Motors is a first rate outfit. Call them. They will make it right.
The bearings are probably insulated, are not subject to arcing, and don't need a ground strap. The frame is the ground. My Nidec motor was like that. I love it.
The wiring was loose on my Nidec too. They didn't prewire it for a given voltage. My biggest bitch was figuring out what wire was what. After a lot of studying, I realized that they were numbered but the numbers were badly stretch so they looked like bar code instead of numbers. After that, it was easy. But my eyes are not getting better with age so I applied number bands anyway. If I were to do it over, I'd use my labeller to make shrink fit labels. But I didn't have a labeller back then. I used these instead.
well I wasn't even offered that option, it now sits in a box waiting for Purolater on the porch......hmmmmmThat's the same motor I bought for my yet-to-be-built 2x42 grinder. It also arrived with the fan guard all bent. There was no damage to the fan so I kept the motor. E-Motors Direct refunded me 50% of the cost so I was happy.
I'm surprised they didn't offer that as well. Assuming the fan is fine, I'd call them back and tell them to refund a big chunk of the cost and all is forgiven.well I wasn't even offered that option, it now sits in a box waiting for Purolater on the porch......hmmmmm
for 50% off I'd bang it out with a hammer and not look at it again, it's gonna cost them to pay shipping and re ship the new one, kinda surprised it wasn't an option.
just called them and they will call me backI'm surprised they didn't offer that as well. Assuming the fan is fine, I'd call them back and tell them to refund a big chunk of the cost and all is forgiven.
