In the shop today
Bofobo
M,Mizera(BOFOBO)
Well i figure i need a spot for the projects that dont require a dedicated write up. Ill start with this modified quad/dirtbike front brake ... um ... mount, its for a volt meter on one of my motorbikes image.jpg
Bofobo
M,Mizera(BOFOBO)
Also today i faced up my BPC wheels but need to center the center holes and find a suitable axle. image.jpg
I also made up the plug and mounted it in the lathe to see if i could turn this size of material and i can although the steady is to small to use image.jpg this will be welded as solid as i can manage on a roller i have yet to build image.jpg
Is that some of the 4140 stock you guys got last year?
What does 'BPC' refer to?
never mind, I get it, saw your other post
Bofobo
M,Mizera(BOFOBO)
This appears to be a non legal document outlining requirements for battle reenactments. Not sure of the relevence.
Annealing sounds like a good enough reason to build the foundry expansion chamber i had planned though
GrayTech
Not sure welding is the best method for a breach plug. I would look into a threaded plug. It needs to be much thicker too.
Johnwa
I believe cannons are treated as antiques even if they are reproductions. Same goes for flintlocks, but amuzzle loading percussion cap gun has to be an original. I don’t think there are any restrictions on importing antique guns but I’ve never did it.
Johnwa
There’s a black powder Brit army shoot in Bowden late June. It doesn’t appear that there will ba any cannon though.
I have made contact with a fellow from Medicine Hat that’s involved in Riel Rebellion re-enactment. They have a ½ scale 9 pounder that they shoot. So far they don’t have any schedule for 2018.
Bofobo
M,Mizera(BOFOBO)
As this is my general shop thread, today i start a new lantern tool post. I need one to hold my smaller boring/threading bar. Now before anyone gets into suggesting i buy a QCTP .... im broke, and i like the lantern style (yes i have used QCTP) added bonus i already have a piece of metal i can use. image.jpg
Bofobo
M,Mizera(BOFOBO)
first a rough size round is cut so i can face in the lathe to dimension, i will also drill the post hole at this time before i square it up rough on the band saw so it will fit in my mill for final sizing image.jpg .... 30 minutes later i realize im hardly cutting and needed to add a few more shoes image.jpg
Keep the pictures of your project coming as it progresses! Is that 4140 you're cutting?
Bofobo
M,Mizera(BOFOBO)
lines scribed, clearances checked and on we go
Johnwa
One of my first projects when I got my lathe was a Williams type holder, much like this one. It handles 3 different sizes of bars and works quite well.
Did someone mention BPC as in Black Powder Cannon? What caliber, how big we talking?
Member historicalarms has lots of experience with the big ones.
