Yeah I'm going from dim memory from 3 years ago when I sheeted the interior.Double sill plates is very uncommon.
That's what thought and remembered from studying Civil Engineering years ago, though I haven't work in the field for a long time to read the current codes.Double top plates are required by code for any load bearing walls, at least here in Ontario they are.
@David_R8 , @Chicken lights
I find that double sill plates are often used in wet environments and on cement. Typically, the bottom sill is rot guarded - pressure treat etc.
Chicken - I think your experience is actually quite common. Exterior and load bearing walls are usually only uncovered for very short periods of time so you wouldn't notice the double top plate. But inside non-load bearing walls are left uncovered and renovations are often single top plate too. Basement insulation walls are almost always singles. If that's what we see all the time we naturally accept it as the norm. But I've never seen an exterior wall with only one top plate in my lifetime. They hold the roof rafters up and those damn rafters never line up with the wall studs. In other words, your experience is perfectly valid.
Spot on Susquatch.
Also, cement is the stuff used to make concrete...concrete is the mix of cement and aggregates that is used for construction 🙂
Had a good chat with my wife last night.
We are shelving the idea of adding on to the existing garage for a number of reasons.
1) The cost to space gain ratio doesn't make sense. We'd have to build the addition, run a new supply from the pole, change meter location, re-wire the garage, trench to the house, re-do the house panel as a sub off the garage. Another 100-110 sq ft for $20,000 is just not worth it.
2) It would be easier to build a motorcycle storage shed on a concrete pad out front of the garage which will free up the 85 sq ft currently used by the moto.
3) Properly designed, I will be able to house the trash and compost containers and possibly incorporate some lumber storage.
4) We are considering adding a laneway house to the front yard to potentially house an aging parent and then as a rental. We talked about adding a second story to the garage as a rental space but we're not confident that a) the structure could take the load or b) that we'd get permits for it.
Nah, my neighbor runs a sawmill and an excavator. Won't scare him with a bit of shop noise ;-)Or move.
PS - I heard they are selling on the island next to @PaulL. Didn't like the noisy new neighbour.......
Yeah we talked about moving too.Or move.
At this point moving is not really that appealing to us. Prices here are really nuts, a house with any amount of land is $1.2M - $2M plus.
Wow is farm land really anywhere near $7500/acre now is Saskatchewan??? I can't believe how farmland prices have become so ridiculous. I think anyone paying crazy high prices doesn't actually think they will recoup the money by farming it but rather by flipping it in to so.eone else that would pay more. Hence the reason I've never been able to farm myself.Move to SK, i will sell you a quarter section for 1.2M, then you can build whatever you want. You may have to convince my daughter to give up some hayland on the deal.🙂
Well seems my moto shed may have hit a snag.
Municipal bylaws state:
1) no sheds in front yards. Front yard is classified as the full width of the property including any laneways or driveways.
2) sheds cannot be used for vehicle storage.
I may go talk to someone at the City Hall but it's likely a no-hoper. 🙁
I’d put cables the cables underground, then there are no restrictions. You could even directional drill them in if you want to not disturb existing structures etc.That's a distinct possibility. If we leave it flat (99.9% likely) we will turn it into a green roof.
