Darbert 10x50 with TouchDRO.
Raglan vertical miller
Interesting results. On mills the majority - 80% - have a pretty big square column or a knee mill. On the lathe front it's really evenly split. Why is that?
I think the results reflect the size of the machine and the space available. It's WAAAY easier to find room for a big mill than a big lathe. So those with limited space have to accept a smaller lathe than they would otherwise want. But they can get a much bigger mill because a big mill only takes up a bit more space than a smaller one does.
It might also be a reflection of the cost difference.
does that size of mill qualify as a square column or a knee?
Looking on the webpage I have in my bookmarks on a teardown, the bed is the up n down part. Hard to argue with your assessment.I believe the Induma 1S is a knee mill.
I'm not the expert on calling this, but my own definition is simple. If the head goes up and down, it's a square or round column mill. If the table goes up and down, it's a knee mill. There are probably a few machines that do both but I don't know which ones.
A quill does not enter the equation. Nor does head nod, or rotate.
..... well, whatcha waiting for? This has project creep written all over it.It could be a reeeaaly good deeal!
One factor may be that more people have multiple lathes than those with multiple mills. And if you can have only one, then it better be big enough to do all the work you needI was planning to wait till we had 50 participants before doing an assessment. But I've already been thinking about the results so far and noticed this too.
