Rock on!🙄..... Looking good.😎Hardware and small stock cart is coming together.
Thanks Don!Rock on!🙄..... Looking good.😎
Don't hate me because I'm lucky 🙂Man. You REALLY suck. I was an hour away from Stuart’s hometown yesterday and was thinking of dropping by to pick up a couple kits and save the shipping, but at $210 each for the smaller kits I just couldn’t justify it. The price you paid for all that stuff is criminal!!!
Jesus...... You mean there's other reasons?🙄Don't hate me because I'm lucky 🙂
Well. Here I thought I'd be pissed off at @DavidR8 because now I'd have to get off my butt and finish a project #42. But it turns out I have some time to contemplate things yet again.That link came out at $6.29 for me plus about $4 shipping so I ordered 2. They will arrive much later so project #42 gets moved a bit. Oh and I ordered Blue anodized. Just for fun.
I think this one looks a bit better. I first tried an aluminum spacer that was 0.125" thick. However it then squished a bit and was tough to remove because it wasn't quite thick enough.Well. Here I thought I'd be pissed off at @DavidR8 because now I'd have to get off my butt and finish a project #42. But it turns out I have some time to contemplate things yet again.
The fitting nuts arrived. Hmmmm. What's wrong with this picture?
Turns out flange to Nut on the cooler is about 0.623" while edge of nut to bottom shoulder is over 0.75". I wonder if that dimension is even a parameter when ordering nuts.
Ah well. I do have a lathe and other than ruining the nice blue I know how to shorten this.
Time for a shop tour for a closer look at your install pretty soon I guess.Looks good, keep at it 🙂
Happy to oblige!Time for a shop tour for a closer look at your install pretty soon I guess.
Well done!I had to bore out the brass fitting to 0.5" to fit the tube into it. Then some cleaning, soldering etc.
Holds air pressure. Looks like my flaring tool works.
Do you want some close up pics of my setup?I did find the hose to quick coupler had a leak when I put soapy water on it. Also ordered one of these:
https://www.amazon.ca/gp/product/B079Q9NM8G/ref=ppx_od_dt_b_asin_title_s00
as the one I have on the end of the regulator is 3/8". This one is 1/2".
Still not sure how I'm going to plumb it all together.
I have a water separator after the compressor regulator and that gets a bit of water.Compressed air systems can always use a good FRL.
The addition of the ‘moisture separator’ will extend the life of your installation, especially if you are using metallic piping and fittings. (Water + Metal = Corrosion)
Air lines tend to collect condensation because of the cooling effects of fast-moving air.
This is undoubtedly the nicest weld I have ever laid down.
If anyone is looking for a MIG machine I recommend the MIG180 from Primeweld.
