We're putting up prefinished birch ply on the ceiling 🙂This won't take long did it! lol
How will you finish the ceiling once the wiring and insulation are in?
You're going to enjoy having the heat pump. I keep my shop at around 15C in the cooler months and 22Cish in the summer.
Heat pump is in!
It will dehumidify, as well as make toast and tea 🙂If that thing will dehumidify, you might want a lower temp in summer to ensure that air in the condenser reaches the dew point. Can't see you complaining about too cold.
How much of your 60A does that thing eat?
Eavestrough
We didn’t prune the apple tree this year 🙁Nice!
But what is with the tree branch hitting the roof? That has to go ASAP!
Yup it's on the Fall cleanup list 🙂Nice. I had about 300 standard size apple trees at my previous place. We have only one here and it is a wild tree about 100 years old. It's on its last leg.
But I'd cut those branches as soon as the leaves fall off this fall. If you cut them now they will go wild. But if they don't get cut soon, they will rub the gravel off the shingles in the wind and also drip enriched water that will allow Algae and Moss to penetrate the backing and degrade the shingles.
David is in Saanich, removing leaves before they fall naturally will require an aborists report, successful passage through three readings before the committee followed by the appropriate applications made in triplicate and the issue of the appropriate permits after payment of the required fee. Of course none of this can happen till after the public consultation.Nice!
Don't forget because he's in Saanich he also can't move any of the leaves faster than 30km/hr and he'll require a leash no longer than 6'.David is in Saanich, removing leaves before they fall naturally will require an aborists report, successful passage through three readings before the committee followed by the appropriate applications made in triplicate and the issue of the appropriate permits after payment of the required fee. Of course none of this can happen till after the public consultation.
So true!David is in Saanich, removing leaves before they fall naturally will require an aborists report, successful passage through three readings before the committee followed by the appropriate applications made in triplicate and the issue of the appropriate permits after payment of the required fee. Of course none of this can happen till after the public consultation.
