DavidR8's shop shenanigans
Were you singing “ OOH I like to do a little sidestep “?
Are you finding the fan blades on the driven pulley provide enough airflow through your air cooler or have you thought about adding an external fan?
Here's the head on my compressor.
If I use my compressor a lot sandblasting I have to drain it at least every every few hours.
The results I've seen online show a really dramatic decrease in air temps. From perhaps 250F at the compressor head to 75F at the tank inlet with equally impressive moisture removal from the temp drop.
Thanks for the info David.
I am going to suggest it to my brother who has a Mobile Sand Blaster for resurfacing farm equipment and heavy machinery (on-site).
@DavidR8 The photo on the Amazon.ca site shows the connectors for what I am guessing is flared soft copper tube? The Derale web site says the inlet and outlet are -8AN size which I believe is 1/2" copper.
You have some sort of black coupler first and then the brass one down to 3/8" which I'm guessing is a compression fitting? Did the cooler come with the shiny black coupler or did you have one or order one from somewhere?
