DavidR8's shop shenanigans
You're not the only one. I've had a few "final" layouts of my shop over the years. I'm on the last one now though...
Looks great David, Bring on the projects.
Thanks Dan.
Here's my project list in no particular order:
-Slow speed carbide grinder a la Stefan Gottewinter
- Make two change gears for the fellow who bought my Clausing
- Build a pantry cabinet for the kitchen
- Build rolling stands for miter saw and thickness sander
- Get CB360T running and out the door
- Build cabinets for lathe base and mill base
Thanks Dan.
Let me see... Let's number them...
1: -Slow speed carbide grinder a la Stefan Gottewinter
2: - Make two change gears for the fellow who bought my Clausing
3: - Build a pantry cabinet for the kitchen
4: - Build rolling stands for miter saw and thickness sander
5: - Get CB360T running and out the door
6: - Build cabinets for lathe base and mill base
Where are the other 42?
All the major pieces are in their new locations.
Still need to build the lean-to for the compressor and dust collector then I will have reclaimed all the floor space.
Everything is on wheels except the metal and wood lathes, jointer, drill press.
Need to build new rolling stands for the miter saw and the thickness sander.
Lots of tidying up to do but it feels much better now.
What kind of castors are on the toaster oven table?
Thanks Dan.
I quit writing them down lol. I WAS working on a 2x72 belt grinder (finally), as I finally got my big tools in a nice layout I could work with, then went and bought a surface grinder which now occupies the spot where the belt grinder would have gone......So I've stalled it for now, and got sucked back into some house projects for a while....Ugh. Looking forward to seeing the grinder and lathe base. Two projects on my list as well.
Turns out the Vevor motorcycle lift is a multipurpose tool :)
Gathering up parts to make a post-compressor head air cooler to reduce the condensation going into my compressor tank.
16 pass transmission cooler from Derale, AN8 to 3/8 NPT and then compression fittings. Automatic drain water separator.
Be interesting to see how well this all works. I guess how often you have to drain tank?
