I like the variety of lengths in this set, but I also like the variety of connections in the set that
@whydontu linked to on Amazon.
Someplace in my electronics shop I have a shoebox of wires (all male both ends) that I used to use for breadboarding. I think all my breadboards are gone though - loaned to various people over the years - usually as completed protype projects for evaluation and never returned. But who knows, I might get a surprise when I look. I'll have to watch the nostalgia hormone levels when I do that.....
Anyway, if you think about the price per wire, neither set is all that expensive.
As a bonus, you can also cut those wires in half and use the ends separately - they are solid wire not braided.
If you do plan to do any prototyping, a small breadboard will save a crapload of soldering.
But, I think it's time that you grew a pair and took on some soldering...... If you can run a mill, a shaper, a lathe, and lord knows what else, you can solder. It's WAY EASIER than you think.
Buy yourself a decent soldering iron for electronics, some fine wire (0.6mm) rosin core solder, some braided copper ribbon for solder removal, a magnifying glass, and a parts holder with tiny alligator clips on a stand.
Here is a Soldering Iron Kit that even includes a Digital Multimeter, Rarlight 60W 110V Adjustable Temperature Welding Tool with ON/OFF Switch, Soldering Iron Tips, Desoldering Pump, Solder Wire, Tweezers, Stand, Screwdriver, and Wire Stripper Cutter.
https://www.amazon.ca/dp/B07L3VNMKX/ref=cm_sw_r_apan_glt_i_BAT62BACA83ATH55XVX5?_encoding=UTF8&psc=1
Here is some desoldering braid - you will love this stuff - it beats a vacuum solder sucker all year long.
https://www.amazon.ca/dp/B008O9VQ5M/ref=cm_sw_r_apan_glt_i_M30965WWDRXRTZYMV3X9
Here are a few parts holders with stand and magnifying glass. Some even have a soldering iron holder. I like the last one cuz it has a third hand.
https://www.amazon.ca/dp/B08FCK33HF/ref=cm_sw_r_apan_glt_i_P6HMMWJXP9EYYNKTS7Y6
https://www.amazon.ca/dp/B08V4B554Y/ref=cm_sw_r_apan_glt_i_6TZM3QWJ9DY5509G2QAR
https://www.amazon.ca/dp/B07JD935J6/ref=cm_sw_r_apan_glt_i_T2H4B3F0PQ4Z9785PAEH
There are lots of choices. That's just what I found on Amazon in a few quick searches. It seems funny that a place called Canada Solder doesn't have much - or I don't know where to look!
